2013-10-11 | images: add a qt4 embedded image | Max Krummenacher | |
still missing automatic start of a demo (and detecting keyboard, mouse, touch) export QWS_DISPLAY="LinuxFb:/dev/fb:depth=24" export QWS_KEYBOARD="USB:/dev/input/event1" export QWS_MOUSE_PROTO="LinuxInput:/dev/input/event2" qtdemoE -qws | |||
2013-10-11 | feed-config: remove non working feeds, add feeds for T30 VF50 | Max Krummenacher | |
- remove links to incompatible architecture feeds - for Colibri T30, Apalis T30 and Colibri VF50 there are compatible feeds - for Colibri T20 there are no compatible feeds | |||
2013-10-11 | console-image: fix the inclusion of X11 | Max Krummenacher | |
2013-10-10 | colibri-vf50: add the machine, kernel and u-boot | Max Krummenacher | |
- also add the relevant configuration files | |||
2013-10-10 | image-fstype: add colibri-vfxx module | Max Krummenacher | |
2013-10-10 | images: cleanup, add colibri-vfxx module | Max Krummenacher | |
- Add optimizations needed for the Colibri VFxx modules - Move common stuff to trdx-extra.inc, /etc/timestamp, CAN utils - Cleanup whitespace and commented stuff - Split out gstreamer packages, don't add them on Colibri VFxx angstrom-lxde-image: - Browser for Colibri VFxx is midori for size reasons console-image: - don't add X11 for Colibri VFxx | |||
2013-09-22 | images: use consistent image names | Max Krummenacher | |
- use consistent image names - while at it build the GLES samples only for a tegra machine | |||
2013-09-22 | image: add handling for imx u-boot extension | Max Krummenacher | |
2013-09-22 | image: add update-alternative and ethtool | Max Krummenacher | |
2013-09-22 | connman: add commandline configuration tool | Max Krummenacher | |
root@colibri-t30:~# connmanctl connmanctl> services *AO Wired { ethernet_00142d259a48_cable } connmanctl> services ethernet_00142d259a48_cable [ ethernet_00142d259a48_cable ] Type = ethernet Security = [ ] State = online Favorite = True Immutable = False AutoConnect = True Name = Wired Ethernet = { Method=auto Interface=eth0 Address=00:14:2D:25:9A:48 MTU=1500 } IPv4 = { Method=dhcp Address=192.168.10.2 Netmask=255.255.255.0 Gateway=192.168.10.1 } IPv4.Configuration = { Method=dhcp } IPv6 = { } IPv6.Configuration = { Method=auto Privacy=disabled } Nameservers = [ 192.168.0.32 ] Nameservers.Configuration = [ ] Timeservers = [ 192.168.0.32 ] Timeservers.Configuration = [ ] Domains = [ ] Domains.Configuration = [ ] Proxy = { Method=direct } Proxy.Configuration = { } Provider = { } connmanctl> config ethernet_00142d259a48_cable --ipv4 manual 192.168.10.2 255.255.255.0 192.168.10.1 connmanctl> exit root@colibri-t30:~# connmanctl connmanctl> config ethernet_00142d259a48_cable --ipv4 dhcp connmanctl> exit | |||
2013-09-22 | inhibit missing debug info warnings in binary package | Max Krummenacher | |
2013-09-22 | stress: correct license text | Max Krummenacher | |
remove backup file while at it | |||
2013-09-22 | lxde: use renamed recipe packagegroup* recipe | Max Krummenacher | |
2013-09-22 | remove obsolete files | Max Krummenacher | |
2013-09-22 | libxi: provide dummy recipe - libxi.bbappend in a layer breaks build | Max Krummenacher | |
2013-09-22 | update-modules: this package is replaced by other postinst | Max Krummenacher | |
2013-09-22 | console-image: use require instead of include | Max Krummenacher | |
2013-09-22 | image: remove line concatenations '\' from comments | Max Krummenacher | |
2013-09-22 | gpioconfig: fix RDEPENDS to include ${PN} | Max Krummenacher | |
2013-08-19 | apalis image: add the v4l camera driver kernel modules | Max Krummenacher | |
2013-08-19 | image: add v4l-utils | Max Krummenacher | |
2013-07-26 | trdx-config: remove obsolete package | Max Krummenacher | |
2013-06-26 | image: move the pixbuf loader update to rootfs creation | Max Krummenacher | |
2013-06-26 | fs-init: add recipe to extend rootfs partition on eMMC | Max Krummenacher | |
- on Colbri/Apalis T30 the rootfs is downloaded in a minimum size. On first boot this filesystem is resized to fill its full partion. This slows down IO responsivness during the first 5 minutes. | |||
2013-06-26 | burnflash: unified T20/T30 | Max Krummenacher | |
- unified the burnflash sources to work on Colibri T20/T30, Apalis T30 - change the PXA dummy burnflash accordingly - increase the initial free rootfs space to 100M on eMMC partition will be resized on first boot to full partition size relevant for Colibri T30, Apalis T30 | |||
2013-06-26 | image: add gstreamer deinterlacer used with camera | Max Krummenacher | |
2013-06-17 | stress: download site is down, added mirror | Max Krummenacher | |
2013-06-07 | lxde-image: add scrot, add underscore to apalis tar filename | Max Krummenacher | |
2013-04-15 | trdx-extra: cleanup indention | Max Krummenacher | |
2013-03-27 | images: added a QT4 X11 image | Max Krummenacher | |
- bbappends to the base qt4-x11-free recipe to use OpenGL ES2 - script which starts X plus qtdemo, including a systemd service to activate script | |||
2013-03-20 | florence: add virtual keyboard to image | Max Krummenacher | |
2013-03-07 | image: add setxkbmap package | Max Krummenacher | |
2013-03-04 | remove unused files | Max Krummenacher | |
2013-03-04 | image: remove intermediate file before creating tarball | Max Krummenacher | |
2013-03-04 | added filesystem tools, Apalis: added lvds configuration scripts | Max Krummenacher | |
2013-02-15 | max9526: added a gtk version for Colibries only | Max Krummenacher | |
2013-02-05 | GPIOConfig: Colibri-t30 GPIO to SODIMM assignment | Max Krummenacher | |
- Colibri T30 V1.1 has a different assignment of GPIO to SODIMM pins | |||
2013-02-05 | image: image name now defined in the image.bb files | Max Krummenacher | |
2013-01-29 | max9526: install on all modules | Max Krummenacher | |
2013-01-29 | image: add Apalis-T30 specific packages | Max Krummenacher | |
2013-01-29 | base-files: add Apalis-T30 | Max Krummenacher | |
2013-01-29 | max9526: i2c userspace driver | Max Krummenacher | |
- sets some registers to setup chip on our ACM analog camera module board | |||
2013-01-29 | glmark2: add recipe for linaro glmark2 | Max Krummenacher | |
2013-01-29 | burnflash: add Apalis-T30 as a deployable image | Max Krummenacher | |
2013-01-22 | GPIOConfig: fix issues with T30 | Max Krummenacher | |
- fix GPIO numbers > 222 not working correctly - fix handling of tristate - fix strings for first alternate function | |||
2012-12-07 | images: add gstreamer plugin mp3, WiFi Firmware, usb-rndis | Max Krummenacher | |
- provide gstreamer plugins which now are required for nvidias mp3 decoder - add firmware for Ambicom WL250N-USB WiFi, - add configuration for usb-rndis | |||
2012-11-26 | image: | Max Krummenacher | |
- add rootfs version to the banner (/etc/issue) | |||
2012-11-22 | burnflash: | Max Krummenacher | |
- prepare for T30 launch - put the rootfs version in the login banner /etc/issue | |||
2012-11-19 | console-trdx-image: | Max Krummenacher | |
- add xserver, and as examples xterm, xclock - cleanup and unify with angstrom-lxde-image | |||
2012-11-19 | trdx-extra.inc | Max Krummenacher | |
- make adding packages specific to colibri-t20, t30 conditonal |
