Use new library libusbg with its automatic gadget configuration
service. Also enable a console on USB gadget serial port (CDC ACM)
which is ttyGS0 on device side.
Use the resize command to set the size of the terminal once upon
login. This is useful for serial console, where the default Unix
signal which takes care of resizing the console (SIGWINCH) is not
available.
There are no more differences in fstab between machines, hence use
the same common file. The default profile has some differences,
however we can seperate them out and create a file which will be
installed in profile.d.
missing
Unifing with imx6 update script pulled in a test that a device-tree
must be deployed. Apalis/Colibri T30 use a not device-tree enabled
Kernel. So remove the check that the device-tree actually exists.
The migration to BSP V2.4 is somewhat more complex due to ECC level
change. The scripts detect whether we are on a new or old module by
checking the NAND driver type (which probably reflects best which
ECC level has been used). In case the NAND driver has the old name
(fsl_nfc), then the script assumes that migration is required:
The migration script runs in two stages:
- The first part updates U-Boot, erases the root file system and
loads the config block into memory (upgrade_part1).
- After reboot, the second stage runs with the new U-Boot version.
The script update the boot configuration block (BCB), restores the
config block from memory and U-Boot is written again using the
new ECC level. Then, the script erases the UBI partition (which
contains the root filesystem) and recreates it using the new ECC
level too (upgrade_part2).
Since we keep the config block temporarly in RAM, the whole update
process should not be interrupted! In case it did, the new U-Boot
version is able to restore the configuration block from command
line.
In contrast to older update scripts, the standard upgrade procedure
does not erase the whole UBI partition anymore. This makes sure that
wear-leveling information can be preserved.
Those packages are not required or not absolutely necessary, hence
remove them for the Vybrid image to loose space constraints on
Colibri VF50 somewhat.
In contrast to the full NTP implementation systemd-timesyncd only
supports the client side of the NTP protocol. In return, the systemd
implementation is ~250kBytes smaller. Since most embedded devices
require client side only, use systemd's timesyncd.
Make the option -o mandatary, used to default to /media/KERNEL
While at it synchronize the files again.
Update to latest version (SVN r671) of burnflash.
Update to latest version (r663) of Vybrid flash scripts.
PublicDomain is not known to OE
Pull out common files of the module specific trees into the common library
directory and symlink the files.
Drop the burnflash.tar.bz2 tarball and put the individual files under
version control.
Only create minimal set for colibri-t20 for now and move it with the
change to tegra-uboot-flasher.
The SUMMARY variable gives a short description of the package (<72 chars).
A missing DESCRIPTION is automatically set to the content of SUMMARY.
${PN} might be extended with some magic prefix, so don't use it in SRC_URI
assignments et. al.
Add the lxde components with meta-lxde packagegroups
and the window and display manager here.
Don't explicitely add packages already added by the lxde package group.
- Make sure leases file is not persistent (in /var/run now)
This allows to serve the same IP to the generated (and hence
different IP addresses)
- Start RNDIS service after the network.target
- Tegra: Add extra service for udhcpd. When running dhcpd directly
from udev, the daemon will be killed after a while
Convert qt-demo-init to a systemd service. The service will only
start when the systemd target is set to graphical, hence also set
the new default target of the qt4e-demo-image to graphical.
Remove debug feed URL as it does not exist.
Re-add Colibri T20 specific (ARM, hard-float, non-neon) feeds which
recently are built in Angstrom again as Atmel SAMA5D3 is non-neon as
well.
If the rootfs in early init is read-only /etc/machine-id is in a tempfs.
systemd-machine-id-commit can be used to migrate to the 'real' rootfs.
The command is run in the installers postinst and thus needs no further
activation.
Switch default kernel recipe to linux-toradex-vf which will build
a kernel based on the toradex 3.18-next branch.
xdg-utils pulls in at least part of the X server.
GPIOconfig tool
Use latest U-Boot from git.
Migrate to using cbootimage and tegrarcm.
Remove explicit installation of ConsoleKit since we use systemd-
logind nowadays. Also, pam-plugin-ck-connector, the ConsoleKit pam
plug-in, is not required anymore. The equavilent for systemd is
part of libpam (pam_systemd.so).
The secondary PolKit authenticatin agent polkit-gnome is not
necessary since LXDE has its own authentication agent lxpolkit.
Due to U-Boot udpate we need to create one big UBI volume. Since
attaching the UBI volume is the expensive operation (compared to
mount the UBIFS inside that volume), it is relatively cheep to
load the kernel directly from the root filesystems /boot directory
instead of creating a own volume for the kernel. This also makes
it simpler to load a mainline kernel (along with the required dtb
file).
However, we loose the integrity check of the uImage. But since
there were no measures in place to handle a invalid image, we do
not loose functionality here. In case we need integrity check, we
should consider switching to the new FIT image format...
BAD_RECOMMENDATIONS seems to not work if more than one package is given
and all packages get installed.
So only give one.
On top of that, if a package is available from multiple feeds the
package gets installed.
Don't install gnome-disk-utility on Vybrid based modules to save space.
u-boot-fw-utils allows for U-Boot environmenmt access from Linux
gpio-export exports the unused GPIOs
usb-rndis sets up RNDIS and a DHCP server on the usb0 NIC
Use the available set of GSTREAMER packages and append the i.MX6 specific ones
to the list instead of providing a new list
