With the change to our own u-boot recipes the bbappend to
the common u-boot-fw-utils recipe is no longer a sane solution.
While at it cleanup COMPATIBLE_MACHINE style.
- build and deploy imx_usb, imx_uart
- currently it builds for the build host arch, i.e x86-64 or i386
tinylogin has been deprecated and the functionality ported into busybox,
so we switch to using busybox as the default login manager.
http://cgit.openembedded.org/openembedded-core/commit/?id=54fc2a698d49f7acc93c8e4b6f6c4e7b3b6ffcc8
Apalis T30 and Colibri VFxx modules have IEEE 1588 (Precision Time Protocol)
capable Ethernet NIC's.
This adds the userspace daemon to such hardware.
The MCC (Multi-Core Communication) is the subsystem that enables MQX
applications running on the M4 core to communicate with Linux
applications on the A5 core
Add initial GPIOConfig for Vybrid (V1.0 Alpha 1)
- move pam-plugin-ck-connector to LXDE image
- remove connman-gnome from Qt image
Add kernel module for Fusion 7"/10" touch screen to the root
filesystem image.
Add the fstrim utility to Colibri T30 image. The utility allows to
send trim commands to the underlaying flash translation layer, which
allows too free not used flash sectors and those improve wear-
leveling
newer distro's tools give the following errors.
stress.texi:68: @itemx must follow @item
ported from meta-linaro:
From e8ba4b6db2c3ec2be54f74d0177bbce2df3f0714 Mon Sep 17 00:00:00 2001
Date: Mon, 1 Jul 2013 12:36:23 +0300
Subject: [PATCH] meta-linaro: fix stress build
incompatible texinfo changes broke this build
- Colibri T30 and Apalis T30 changed to NEON
- Colibri VF50 changed to hard float
This makes packages built for T30 incompatible with Colibri T20
(but Colibri T20 packages can still be used on T30)
still missing automatic start of a demo
(and detecting keyboard, mouse, touch)
export QWS_DISPLAY="LinuxFb:/dev/fb:depth=24"
export QWS_KEYBOARD="USB:/dev/input/event1"
export QWS_MOUSE_PROTO="LinuxInput:/dev/input/event2"
qtdemoE -qws
- remove links to incompatible architecture feeds
- for Colibri T30, Apalis T30 and Colibri VF50 there are compatible feeds
- for Colibri T20 there are no compatible feeds
- also add the relevant configuration files
- Add optimizations needed for the Colibri VFxx modules
- Move common stuff to trdx-extra.inc, /etc/timestamp, CAN utils
- Cleanup whitespace and commented stuff
- Split out gstreamer packages, don't add them on Colibri VFxx
angstrom-lxde-image:
- Browser for Colibri VFxx is midori for size reasons
console-image:
- don't add X11 for Colibri VFxx
- use consistent image names
- while at it build the GLES samples only for a tegra machine
root@colibri-t30:~# connmanctl
connmanctl> services
*AO Wired { ethernet_00142d259a48_cable }
connmanctl> services ethernet_00142d259a48_cable
[ ethernet_00142d259a48_cable ]
Type = ethernet
Security = [ ]
State = online
Favorite = True
Immutable = False
AutoConnect = True
Name = Wired
Ethernet = { Method=auto Interface=eth0 Address=00:14:2D:25:9A:48 MTU=1500
IPv4 = { Method=dhcp Address=192.168.10.2 Netmask=255.255.255.0 Gateway=192.168.10.1 }
IPv4.Configuration = { Method=dhcp }
IPv6 = { }
IPv6.Configuration = { Method=auto Privacy=disabled }
Nameservers = [ 192.168.0.32 ]
Nameservers.Configuration = [ ]
Timeservers = [ 192.168.0.32 ]
Timeservers.Configuration = [ ]
Domains = [ ]
Domains.Configuration = [ ]
Proxy = { Method=direct }
Proxy.Configuration = { }
Provider = { }
connmanctl> config ethernet_00142d259a48_cable --ipv4 manual 192.168.10.2 255.255.255.0 192.168.10.1
connmanctl> exit
connmanctl> config ethernet_00142d259a48_cable --ipv4 dhcp
connmanctl> exit
remove backup file while at it
