We want to append to the generic VAR when we build for a tegra machine.
Using VAR_tegra += "" creates a machine specific VAR.
The Linux Kernel 4.4 for Colibri VF does currently not support the needed
interfaces for mcc.
e.g. look for files in ${board} subdirectory rather than in the media's root.
Newer xserver recipes dropped some packages, move them to RRECOMMEND
rather than adding it to IMAGE_INSTALL. That way the image build
independently of the used xserver version.
midory has been dropped from oe-core
When building for a second machine after building for one the rootfs
creation fails because some license files are not found.
I belive this is caused by the following commit:
https://github.com/Angstrom-distribution/meta-angstrom/commit/dae094d69a1f8651c822fb35d606bf59a615f244
All packages which are created from sstate fail do install in the rootfs
likely because the license file is only available in the subdirectory of
the machine for which it was originally built.
Write kernel and device tree into seperate UBI Volumes. This
allows to use a lot less UBI/UBIFS support in U-Boot, which
should lower the risk of hitting bugs in this area. Boot times
are also slightly faster (measurements showed an improvement of
~150ms).
Enable USB suspend resume fix for Vybrid.
Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com>
When using TFTP update, the rootfs must be in decimal numbered chunks on the
tftp server. U-Boot reads the chunks, but does count hexadecimal thus
limiting the number of chunks to 10.
The U-Boot binary for the IT temperature range changed names from
u-boot-it.imx to u-boot.imx-it.
The flash_*.scr scripts did still use the old name resulting in the U-Boot
not being found on the SD card or TFTP server.
Avoids
WARNING: Unable to get checksum for gpioconfig SRC_URI entry GPIOConfig: file could not be found
during recipe parse by providing a dummy GPIOConfig.
The dummy displays a popup with a button that says that the program is not
available on this machine.
(cherry picked from commit e6959294ac99c87c7aabe2334d6582618ea3a825)
This has been missing since our move to boot from the eMMC boot partition.
While at it clarify update.sh help. _it applies only to
Apalis iMX6 IT modules.
Change the name form u-boot-it.imx to u-boot.imx-it.
This prepares for the upcomming move of the i.MX 6 based modules BSP
to meta-fsl-arm-extra.
The command 'mmc partconf 0 1 1 0' seems to have no effect when it is in the
middle of our migration cmdline resulting in U-Boot still being loaded from
the user partition.
Putting it as the last command seems to solve the issue.
http://developer.toradex.com/software-resources/arm-family/linux/linux/release-details?view=all&issue=14774
The LM006 USB WiFi adapter uses a Realtek RTL8188CUS chipset,
which requires the compatible firmware RTL8192CU.
Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com>
With the cfgblock command in U-Boot we now have a better solution.
Don't write the eMMC twice on Apalis in the not migrate case.
Since we use USB Gadget ConfigFS now use libusbg to load the
USB Gadget configuration automatically.
Up until now, U-Boot for Colibri VF50/VF61 did not had an
environment variable board_name. Use the soc environment
variable to set the board_name.
To avoid code duplication call fwd_blk from fwd_mmc. This adds
one more indirection, but since flash_mmc.img is a compatibility
script anyway it is not the common case...
Source the update script only if loading succeeded. This avoids
loops if board_name is not set. Also add a test if board_name is
really set since this variable is/was not available in older
U-Boots.
Further generalise U-Boot update scripts by using ${board_name} instead
of hard coding module name like apalis_t30, colibri_t20 or colibri_t30.
Even though our downstream L4T based kernel does not use any
device tree stuff prepare for easy deployment thereof by using the
correct dtb name.
In the Ethernet aka TFTP update case this actually fixes an issue where
it previously tried to TFTP the whole ${board_name} directory which at
least on my setup failed with a permission denied which it retried
forever.
Deploy and enable CPU hot-plug configuration and startup on our T30
based modules. This significantly reduces power-consumption and
therefore improves thermal characteristics.
meta-openembedded provides a recipe for joe, use that one.
This reverts commit ae568dc9b001306a0723daccf3ea7912d94438ee.
http://cgit.openembedded.org/openembedded-core/commit/meta/recipes-core/systemd/systemd_219.bb?h=fido&id=0cd5a0d5445ff95a8ef4abe24fef705957935e81
fixes the automount issues we have during boot.
So revert the patch which completely disabled the feature.
This reverts commit a1040ca051f6c66bc5205502a462d55490653360.
This (re)introduces the issue that removable media attached during runtime
does get mounted with dbus / udisk in a different fashion.
But the fact that media connected at boot is actually mounted before the
system reaches its running state and that automount works when one disables
the start of the display manager outweights this.
Update our U-Boot update scripts to accommodate our new unified eMMC
layout:
boot area partition 1 aka primary eMMC boot sector:
with U-Boot boot loader and the U-Boot environment before the
configblock at the end of that boot area partition
Handle migration of boot loader and configblock on Apalis/Colibri iMX6.
When doing a full update also explicitly flash kernel and FDT from the
update medium in order to allow for easy updating thereof.
Further clean-up and unify our update scripts:
- Universally mention Ethernet aka TFTP, SD card and USB flash drive as
possible update media.
- Universally mention detailed recovery/update procedures being
available on our developer website.
- Universally split usage and flashing instructions (-f).
- Make sure we don't exceed the 80 characters line length limit.
- Fix various spelling issues.
Now that both Apalis/Colibri iMX6 as well as Apalis/Colibri T30 will
use the same eMMC layout also concerning boot loader, environment and
configblock locations in the primary eMMC boot area partition update
resp. description.
The following commit:
f463f754048ebc3325025f0e1506b03cf14203a5
update.sh: use moduletype specific folder for output files
moved the output folder check above the module type selection which now
fails in case of debug aka recovery mode only operation with the
following error:
does not exist, exiting
This patch fixes this by not erring out in the debug aka recovery mode
only operation if no output folder is set.
With update.sh one creates files on e.g. a SD-card or a tftp server
which enables updating the SW on a module from U-Boot running on
said module.
This commit adds a module type specific directory on that output media
so that update data for multiple module types can be stored on one media.
Generic U-Boot scripts in the media's root directory do select the
matching update data depending on module type.
