path: root/release-notes
2015-03-25Update release notesMarcel Ziswiler
2015-02-12Update release notesMarcel Ziswiler
2015-02-06Apalis/Colibri iMX6: Update release notesMax Krummenacher
Add issue with getty also started on ttymxc1.
2015-02-04Colibri VF50/VF61: Update release notesStefan Agner
2015-01-13Apalis iMX6: Update release notes for Beta6Max Krummenacher
2015-01-09Apalis iMX6: Update release notesMax Krummenacher
2014-12-19Apalis/Colibri iMX6/T20/T30/VF50/VF61: Update release notesMarcel Ziswiler
2014-12-08Colibri iMX6: Update release notesMax Krummenacher
Add update of single component U-Boot/Kernel/FDT Remove unavailable interfaces from the list of notworking Add correct git tag
2014-12-08Release Notes: fix changed URLMax Krummenacher
While at it remove supperseeded release note
2014-12-08Colibri iMX6/T30: Add/Update release notesMax Krummenacher
Add inital release notes for Colibri iMX6 Fix Colibri T30, EvalBoard MMC connector designator
2014-12-08Apalis/Colibri T30: Update release notesMax Krummenacher
Workaround for resize script
2014-11-13Apalis/Colibri iMX6/T20/T30/VF50/VF61: Update release notesMarcel Ziswiler
2014-11-05Apalis/Colibri iMX6/T20/T30/VF50/VF61: Update release notesMarcel Ziswiler
2014-11-03Apalis/Colibri T30: Fixed release notesMarcel Ziswiler
Got the U-Boot stuff mixed up.
2014-11-03Apalis/Colibri iMX6/T20/T30/VF50/VF61: Update release notesMarcel Ziswiler
2014-10-06apalis-imx6: Release notes: update from V2.2 on IxoraMax Krummenacher
Conflicts: release-notes/Apalis_iMX6_LinuxReleaseNotesV2.x.txt
2014-09-14apalis/colibri iMX6/T20/T30/VF50/VF61: Update release notesMarcel Ziswiler
2014-09-04Apalis T30: Update release notesMarcel Ziswiler
2014-09-02apalis-imx6: Release notes: add notes for PCIe configMax Krummenacher
2014-09-02apalis-imx6: Release notes: add saveenv to env updateMax Krummenacher
2014-09-02apalis-imx6: Release notes: Use webfriendly " charMax Krummenacher
2014-08-05apalis/colibri iMX6/T20/T30/VF50/VF61: Update release notesMarcel Ziswiler
2014-06-12release notes: extend Colibri VF UART recovery notesStefan Agner
Add hint for non-fused modules, document recovery mode on Iris.
2014-06-10release notes: update Colibri VF release notesStefan Agner
Update Colibri VFxx release notes to reflect latest release V2.2 Beta 1.
2014-04-08Added note about Apalis iMX6 SSH password authentication beingMarcel Ziswiler
disabled by default. While at it line wrapped Apalis T30 release notes document.
2014-04-04Apalis_iMX6: add initial rlease notesMax Krummenacher
2014-03-20release notes: Colibri VF: add boot hang issueStefan Agner
Add boot hang issue to known bugs.
2014-03-18release notes: apalis/colibri t20/t30 colibri vf v2.1 beta 3Max Krummenacher
2014-03-06release notes: vybrid beta 2 release notesStefan Agner
2014-02-13release notes: apalis t30Marcel Ziswiler
Add a note concerning suspend LP1 being untested resp. it currently failing due to igb/PCIe issues.
2014-02-10release notes: apalis/colibri t20/t30 v2.1 beta 2Marcel Ziswiler
2013-10-25release notes: colibri vf50 fix strapping resistor valueMarcel Ziswiler
2013-10-25release notes: colibri vf50 v2.1 beta 1Marcel Ziswiler
2013-10-25release notes: apalis/colibri t20/t30 v2.1 beta 1Marcel Ziswiler
2013-08-30Colibri T30, Apalis T30: update release notesMax Krummenacher
2013-08-27Colibri T30, Apalis T30: update release notesMax Krummenacher
2013-08-27release notes: Apalis T30 updateMax Krummenacher
2013-06-27release notes: updated to T30_LinuxImageV2.0Beta2_20130626 ↵Max Krummenacher
Apalis_T30_LinuxImageV2.0Beta1_20130626
2013-06-27release notes: add all release notes 2013-05Max Krummenacher
