This is the result of automated script (0.9.3) conversion:
../openembedded-core/scripts/contrib/convert-overrides.py .
+# meta-toradex-distro
+vars = vars + ["preempt-rt","tdx","upstream"]
+# meta-toradex-* machines
+vars = vars + ["apalis-","colibri-","verdin-","tegra124"]
+# meta-freescale
+vars = vars + ["imx","mx6","mx7","mx8","use-mainline-bsp","use-nxp-bsp"]
converting the metadata to use ":" as the override character instead of "_".
Openembedded core no longer provides the class. Remove it.
See commit 908df863b4 ("mklibs: remove recipes and class")
To involve in basic sanity check for Toradex builds.
Related-to: ELB-3944
Signed-off-by: Ming Liu <ming.liu@toradex.com>
(cherry picked from commit a12eef0d00f2dce08e65ac3b70075a21abc5c5dc)
It's by default disabled, the end users could choose to enable them by
uncommenting two lines.
Related-to: TOR-1700
(cherry picked from commit ff7025a26e13326eb12444fb853de655629378e0)
Related-to: ELB-2303
(cherry picked from commit 1e0d10b2851ac455618ab7e4c7db86c9ad1227a0)
(cherry picked from commit 276c966a04bbe4d19866becb3b8fc147d1079049)
The downstream kernel gets to old to be used with the new zeus
userspace components. Reuse the apalis-tk1 machine name to build
a mainline kernel and drop the apalis-tk1-mainline machine.
Related-to: ELB-2733
(cherry picked from commit 7f8cd66bb84f32c3b7dd4eea95ba9482786770c0)
The 'Parallelism Options' are now set in bitbake.conf to a sensible default.
Some options are now set with ?= to allow for easier overrides.
A lot of trailing whitspace has been removed.
Add the new machine now available from meta-toradex-nxp.
Since apalis-imx8x has been supported in meta-toradex-nxp layer, add it
into local.conf.
NXP dropped X11 support for i.MX8 and i.MX8X.
Thus build our images with the tdx-xwayland distro configuration.
We decided we won't do a BSP 3.0 for Vybrid.
For new designs we recommend ULL now.
There is a resonable default in bitbake.conf. For all our machines it is also
set explicitely so there is no need to carry this in local.conf.
Move the DEPLOY_DIR directory to be inside the build directory.
Using the same layer metadata to create two independent build directories
(e.g. for two builds of the same machine but with different kernels)
now has the deploy directory name no longer clash.
Move DL_DIR and SSTATE_DIR to the root of the oe installation.
This then automatically shares downloads and sstate between different build
directories.
Also adapted to use the now available tdx-x11 distro.
