SIT tunnels (IPv6 over IPv4) are not often used hence configure
the driver as a module. This also gets rid of the extra network
interface sit0 by default.
Add default xorg.conf for Vybrid based modules. This makes sure that
the DRM enabled modesetting DDX driver gets used.
Auto-load rpmsg/remoteproc modules during boot.
Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com>
Update defconfig to build rpmsg and remoteproc.
Synchronize defconfig with kernel git.
The DRM driver fbdev emulation does not support setting modes
using fbset:
ioctl FBIOPUT_VSCREENINFO: Invalid argument
Remove the fb.modes configuration file as it provides no value
anymore.
Move the appends on recipe's which are not in an essential required layer
into a target layer specific directory and add them only if said layer
is active in build/conf/bblayers.conf.
Do not use the function keyword, then the script works fine with
with Busybox' shell implementation.
While we use only one erase block for the U-Boot environment, we
reserve four in case there are bad blocks in the environment area.
Specify the number of blocks so that the Linux utilities are able
to read/write the environment even if the first block of the
environment is bad.
Rely on newly implemented configuration functionality to locate the
environment at the end of the boot partition.
Resynchronize defconfig with the git tree version:
The audio Codec Machine driver was missing hence the sound card
got not detected by the SAI driver.
Remove Kernel image and device tree from rootfs since we start using
static UBI volumes.
While we enable CONFIG_IIO_SYSFS_TRIGGER in kernel source defconfig
this is not enabled in defconfig being used in OpenEmbedded. This
results in sysfs triggers not being enabled by default in an image
build with OpenEmbedded. This is already observed with our last
release 2.6 Beta1 image.
The upgrade is required to match to the latest update scripts which
deploy the kernel and device tree into static UBI volumes.
A new i.MX6/i.MX7 real-time 3.14.52 kernel recipe was added with a
modified PREEMPT_RT patch to accomodate the backports applied to
the Toradex kernel.
To select the kernel use a preferred provider variable in your
configuration files (e.g. local.conf):
PREFERRED_PROVIDER_virtual/kernel = "linux-toradex-fsl-rt"
Signed-off-by: Brandon Shibley <brandon.shibley@toradex.com>
Use KERNEL_MODULE_AUTOLOAD to load USB gadget support. This is
required for libusbg (gadget-import) to work.
Update defconfigs and drop picking the defconfig from the kernel sources.
A new i.MX6 real-time kernel recipe was added with a modified
PREEMPT_RT patch to accomodate the backports applied to the
Toradex kernel.
Fix build failure because mqxboot_2.x is built instead of the
required mqxboot_1.x.
The mqxboot version changed from 1.0 to 1.0.1.
Choosing the preferred version with a wildcard prevents using
the not compatible 2.x version.
NOTE: preferred version 1.0 of mqxboot not available (for item mqxboot)
NOTE: versions of mqxboot available: 1.0.1 2.0.1
While at it set the prefered providers for mcc related recipes.
(ported from meta-fsl-arm-extra 6eefe6562d51525ff511adf81a84ad7af8a25814
and 0f4942175f8ae00741b2fee2ab82ceedb58f15c3)
Signed-off--by: Max Krummenacher <max.krummenacher@toradex.com>
This overrides the meta-fsl-arm provided settings from machconfig.
