Use '${COMMON_LICENSE_DIR} for license files
fix the warning:
| WARNING: packagegroup-xfce-base-1.0-r5 do_populate_lic:
| ${COREBASE}/LICENSE is not a valid license file, please use
|'${COMMON_LICENSE_DIR}/MIT' for a MIT License file in LIC_FILES_CHKSUM.
|This will become an error in the future
Set Toradex and git hash versions in the same way as what
is upstreamed to meta-freescale-3rdparty.
Include a file to the machine configuration to amend to the upstream
$MACHINE.conf file.
The recipe is meant for Vybrid based modules, so enable the service only
for vybrid rather than disabling it for an (incomplete) list of machines
which are not vybrids.
With UBOOT_CONFIG one can build several U-Boot configs, however
the current code does fail if these build mixed spl and non spl
based U-Boots.
This works around the issue by generating a fake SPL file and
delete it after its presence is no longer needed.
Add a inc file to allow downstream specific amendments.
Currently used to inject Toradex Easy Installer image creation.
Upstream U-Boot 2016.11 for all NXP based modules to meta-freescale-3rdparty.
Remove the files for the older 2015.04 based U-Boot.
Upstream the kernel for a fslc-imx 4.1-2.0.x based kernel for Apalis/Colibri iMX6
and Colibri iMX7 to meta-freescale-3rdparty.
Remove the files for linux-toradex_3.14.52 and linux-toradex_4.1.15 kernels.
The 2.7.2 image version is now upstreamed to meta-freescale-3rdparty.
While at it add a config for colibri-imx6ull, add the Atmel touch driver and
follow the move of the colibri-imx7 -> mx7 override in the non rt defconfig.
Signed-off-by: Drew Moseley <drew.moseley@northern.tech>
Build and deploy the device tree for the Colibri iMX6ULL 512MB Wi-Fi / BT.
This can be used e.g. for a CI setup to do nightly builds of latest and
greatest.
To use HEAD of xxx-next instead of the pinned version one would add
in local.conf:
MACHINEOVERRIDES =. "use-head-next:"
greatest.
in local.conf:
The kernel lives in its own ubi volume. Save the space in the rootfs.
Prepare for configurable boot ROM and SPL payload offsets to be applied
to resp. image.json for Toradex Easy Installer.
RPM packaging does not allow a dash '-' in the revision name.
Use u-boot-nand.imx which has a 1kB padding so it can be written
directly to flash.
Add support for Toradex Easy Installer by specifying Toradex
product ids and flash type.
Building the recipe with Poky leads to two errors:
| error: line 4: invalid tag value("^[A-Za-z0-9+._]+$") Release: Release: 2.7.3-gitr1c83a29
| error: Package has no %description: u-boot-toradex-2016.11.colibri_imx6
Use the + sign to separate the git revision and provide a recipe
description.
All kernel drivers to support eMMC are already present, hence this
uses the same defconfig as colibri-imx7 machine uses.
Thus use a soc override to provide the defconfig for both
colibri-imx7, colibri-imx7-emmc.
Add fw_env.config and make sure unlock eMMC gets installed.
The workaround for U-Boot being compiled with and without SPL
assumes a certain directory structure. For machines only building
one U-Boot, the workaround may introduce and error.
Fix this.
This allows for machine variants, additonally it adds colibri-imx6ull
Building device tree with a dot in the file name leads to following
ERROR: console-tdx-image-2.7b3-r0 do_image_sdcard: imx6q-apalis-ixora-v1.1.dtb does not exist.
ERROR: console-tdx-image-2.7b3-r0 do_image_sdcard: Function failed: do_image_sdcard
Temporarily remove until we have support for dots in device tree files:
https://github.com/Freescale/meta-freescale/commit/ce1e0af209c222cb877962104c4f807d5807fa1e
Add new machine file for Colibri iMX7 Dual 1GB (eMMC) modules.
Adjust defconfigs for use with backports
linux-toradex-4.1-2.0.x/defconfig is not building for machine
apalis-imx6, colibri-imx6, or colibri-imx7.
But the kernel does not (no longer`) build for this configuration.
| LD init/built-in.o
| drivers/built-in.o: In function `mxc_hdmi_disp_init':
| coresight-etm-cp14.c:(.text+0x4499c): undefined reference to `mxc_cea_mode'
Ixora V1.1
Add Ixora V1.1 device tree to Apalis iMX6 OE machine configuration.
Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com>
