This reverts commit d6f3d5f70907d2f8f2c653a55f314d7213090635.
This now lives in meta-freescale.
This reverts commit 7d38656c1afcd3d27240ffc327321f752def6b3c.
This reverts commit eb357d91457c8f33d06c7481440e3b6842039aa7.
recipes-graphics/imx-gpu-viv/imx-gpu-viv-6.inc
Already removed by earlier revert
This reverts commit 9644f8c076d677d6c74674e889eb1dc66d36f827.
This reverts commit de504a1923f09ea25e0beb1ccc375e113e207067.
This reverts commit 5a6074a815b83a443751bf97c910be71774a4404.
This reverts commit 9ccc8d64a880e0d193b88abfd7742e19fe6cc71a.
This reverts commit 1e0a57f744b0dd42ac7025ee0ed540f940291c57.
This reverts commit 7e4cb11489a8a16bbf154ebb42da88b5a41fde3e.
meta-freescale now moved to a newer version of the driver which fixed the issue
with moving to git. Thus the bbappend is no longer needed.
This reverts commit 46e0ede0d617b28dd37f0e4e868476db1282126f.
This reverts commit d7f477890815e2aa7f6c2fc78e8004c83deb970a.
This reverts commit 04e23f29eddd5691abed947a2e0dd364259248dc.
This reverts commit 6ea16f817f7bafd02458163efadb488192cfaab2.
This reverts commit 6cf4769de230d8c902b3419f50ee26abca028688.
This reverts commit 272a7cb554098ddc3939862df8e19e74d055aeea.
Acked-by: Philippe Schenker <philippe.schenker@toradex.com>
Update to L4.9.123-2.3.0_8mm_ga release.
Update to branch toradex_4.9-2.3.x-imx based on 4.9-2.3.x-imx branch of
linux-fslc currently re-based to 4.9.144.
Actually make use of them various upgrades.
As per meta-freescale commit 927b31771dab ("xf86-video-imx-vivante: Remove fb
from name") this recipe got renamed and should no longer be used!
Pulled from 6c1f35fdd5a762a3376c314dd36c564858d20cdb on
meta-freescale/master.
Pulled from 0f8d9894f9d7af73411883707c262911537f2695 on
Pulled from f1e26d9de04bc80aeff8e8e31e2f0862f0556419 on
We do want it for epxp support, however, later versions moved from using
kernel-headers to libdrm includes.
Signed-off-by: Carlos Rafael Giani <crg7475@mailbox.org>
Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
(cherry picked from commit 076b00fcd36d30171e6f50ac0c4abd7e4ac82e1d on
meta-freescale/master)
Update to L4.9.123-2.3.0_8mm_ga release:
gstreamer1.0-plugins-imx update from 0.13.0 to git 963aea60b1
imx-gst1.0-plugin update from 4.3.4 to 4.4.2
gstreamer1.0 update to 476c63185e6864f82e938247235e7ad8ad20af4b on
Pulled from 30d8e9ad3aea13417a73979215412b3df9871d6d on
Pulled from 72dac5cac22806baf44610519e8091b528c79218 on
Pulled from c9bb48f2887667c59b8353e7ab5e44e41324375a on
Pulled from 1594c64aa5d51a0c97835f6548215fb0b48e0a34 on
Pulled from aac087e42024c290adf34d93ce57a3e8ace2c23f on
Pulled from 17a43b80cee64ef1cf25ae1f1ce8bc81596fb91d on
Pulled from 86000786e5d86bf0fc9f919b74f17a1d825d6351 on
Add support for new SKU 0045 WiFi non-IT variant.
Device trees for the carrier board Aster are now available, deploy
them.
This is required since meta-freescale commit a4158e3425a7
("gstreamer1.0: Set DEFAULT_PREFERENCE as -1 to imx version") et. al.
and is analogous to meta-freescale-distro commit 29e7a3d322c7
("fsl-base.inc: Set PREFERRED_VERSION for Gstreamer to use i.MX Version"
Colibri iMX6ULL and Colibri iMX7 were added as according to the i.MX
Reference Manual L4.1.15_2.1.0-ga they at least could profit from the
Pixel Pipeline (PxP) DMA-ENGINE driver.
When building the SDK one gets a warning and most -dev packages do not
get installed.
| * Problem 1/1:
| * - package libgl-imx-dev-1:6.2.2.p0-aarch32-r0.armv7at2hf-neon-mx6q
dl requires libgl-mesa-dev, but none of the providers can be installed
The opkg file for libgl-mesa-dev exist but somehow is not considered for
installation. Not depending on it at least installs the other -dev
packages.
See also:
https://www.toradex.com/community/questions/19849/bitbake-do-rootfs-failed-with-rocko-and-dev-pkgs-i.html
Enforcing to build 32-bit binaries for native and portions thereof
using -m32 in EXTRA_OEMAKE_class-native may lead to building errors.
Also, it seems it's time to move on from 32-bit compatibility.
Affected repositories:
meta-toradex-demos
meta-toradex-nxp
meta-toradex-tegra
Signed-off-by: Gerard Salvatella <gerard.salvatella@toradex.com>
Adjust defconfigs for use with backports
While at it use consistently the .xz compressed rt-patch file.
The device tree got changed to use the simple card driver, so enable it
in the defconfig.
While at it remove the IMX_SGTL5000 driver now replaced by the simple card driver.
While at it remove the unused ESAI driver.
While at it remove the unused CS42XX8_I2C codec driver.
Add support for new SKU non-WiFi IT variant.
It wrongly assumed lib64 layout if building on 64-bit machine.
This i.MX specific version is based on v2.4.84
Signed-off-by: Yuqing Zhu <carol.zhu-3arQi8VN3Tc@public.gmane.org>
Pulled from meta-freescale mailing list.
This resp. a later version got recently pulled into the rocko branch of
meta-freescale.
This reverts commit 5faa79028eead21680d490a1b589a3875f966e0e.
