Use u-boot-nand.imx which has a 1kB padding so it can be written
directly to flash.
Add support for Toradex Easy Installer by specifying Toradex
product ids and flash type.
Building the recipe with Poky leads to two errors:
| error: line 4: invalid tag value("^[A-Za-z0-9+._]+$") Release: Release: 2.7.3-gitr1c83a29
| error: Package has no %description: u-boot-toradex-2016.11.colibri_imx6
Use the + sign to separate the git revision and provide a recipe
description.
All kernel drivers to support eMMC are already present, hence this
uses the same defconfig as colibri-imx7 machine uses.
Thus use a soc override to provide the defconfig for both
colibri-imx7, colibri-imx7-emmc.
Add fw_env.config and make sure unlock eMMC gets installed.
The workaround for U-Boot being compiled with and without SPL
assumes a certain directory structure. For machines only building
one U-Boot, the workaround may introduce and error.
Fix this.
This allows for machine variants, additonally it adds colibri-imx6ull
Building device tree with a dot in the file name leads to following
ERROR: console-tdx-image-2.7b3-r0 do_image_sdcard: imx6q-apalis-ixora-v1.1.dtb does not exist.
ERROR: console-tdx-image-2.7b3-r0 do_image_sdcard: Function failed: do_image_sdcard
Temporarily remove until we have support for dots in device tree files:
https://github.com/Freescale/meta-freescale/commit/ce1e0af209c222cb877962104c4f807d5807fa1e
Add new machine file for Colibri iMX7 Dual 1GB (eMMC) modules.
Adjust defconfigs for use with backports
linux-toradex-4.1-2.0.x/defconfig is not building for machine
apalis-imx6, colibri-imx6, or colibri-imx7.
But the kernel does not (no longer`) build for this configuration.
| LD init/built-in.o
| drivers/built-in.o: In function `mxc_hdmi_disp_init':
| coresight-etm-cp14.c:(.text+0x4499c): undefined reference to `mxc_cea_mode'
Ixora V1.1
Add Ixora V1.1 device tree to Apalis iMX6 OE machine configuration.
Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com>
Also include the patch from Julio Cruz which allows to use the external
vivante kernel module from meta-freescale.
snapd requires squashfs kernel module but this has not been added
to all defconfigs.
Follow commit f0d525d36e915076416a443eb15a69efdcac1e73
or the images which add the snapd packagegroup will not build
As somebody previously decided to rename U_BOOT_BINARY to UBOOT_BINARY
unbreak e.g. i.MX 6 Tezi builds by continuing that rename through the
various layers:
http://git.toradex.com/cgit/meta-toradex-bsp-common.git/commit/?h=morty&id=02f7fdfe5eaca64e0c710cce4d701a609d499e8b
Add machine definition for Vybrid. The Vybrid machine definition
is already present in meta-freescale-3rdparty. Add the same to
the meta-toradex-nxp layer to be able to deploy Aster device
trees.
Add Aster device tree to Colibri iMX6 OE machine configuration.
Add Aster device tree to Colibri iMX7 OE machine configuration.
Add Linux kernel recipe which patches the Toradex Colibri VF50/VF61
kernel with the 4.4.60-rt73 PREEMPT RT patch set.
Add Toradex Easy Installer support by enabling the tezi image
format. Also specify the Product IDs this machine is compatible
with and the device tree associated with them. This is used on
devices where we have variants using different device trees but
were built using a single OpenEmbedded machine.
Disable the fusing/one-time-programmable driver by default. It
allows to blow fuses which might make the module unusable with
a simple sysfs write...
This linux userspace tool does what U-Boot's 'bmode usb noreset' does.
On the next reboot the i.MX 6 will boot to recovery aka serial download
mode.
This results in a U-Boot banner:
U-Boot 2016.11-2.7.2+g3e67ed8 (Apr 05 2017 - 16:16:38 +0200)
While at it extract the versioning into its own bbappend so that we
can upstream the base recipe to meta-freescale-3rdparty
While at it remove double assignement to 'S'.
In our images this has been done during do_rootfs and friends,
do it the oe-core way.
To select the kernel use a preferred provider variable in your
configuration files (e.g. local.conf):
PREFERRED_PROVIDER_virtual/kernel = "linux-toradex-fsl-rt"
Signed-off-by: Brandon Shibley <brandon.shibley@toradex.com>
While at it clean-up and unify with other Toradex layers.
meta-fsl-arm* was renamed and changed to meta-freescale* with morty.
Configure Bluetooth to be built as kernel modules by default. This
allows to make use of USB/SDIO based Bluetooth solutions easier.
The "tezi" image type has been renamed to "teziimg".
