This gives the codec reasonable mixer defaults.
Without this a getty on the non existing ttyS0 gets additionally started
which then fails and gets continously restarted.
Resync with the defconfigs from the kernel repository. This adds:
- enable USB WiFi adapter.
Related-to: #58517
Resync with the defconfig from the kernel repository. This adds:
Related-to: #32198
Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
Taken from meta-freescale, commit eb2b9bf4cefa47175e76eaa50d4a58b5117bdc72
The U-Boot recipe decorates u-boot-nodtb.bin with machine and configuration.
The device-trees search the sdma firmware in /lib/firmware/imx/sdma/ so
actually deploy it there.
Synchronise with kernel defconfig
- add USB HID raw support
- enable ext4 file system security support
(cherry picked from commit 557a0e42badba143a8c0b3b0ef0eb1d4ebb5ee10)
- enable USB-to-serial adapters
- add load edid support
Related-to: #57567
(cherry picked from commit b103c379c216b5e370e7702b3e586e81c38625bb)
This reverts commit e3e5aba1c725ad3ff4daf128ad525625923a653d.
Enable zram which is useful for compressed swap space in memory. This is
especially useful on embedded devices where swap space on a block device
is not typically enabled (to avoid flash wear).
Resync with kernel defconfig, this includes:
- defconfig: fix delayed mxt loading
- defconfig: fix ip firewall (bpf/cgroup)
Fix QA issue: SRC_URI uses PN not BPN [src-uri-bad]
Signed-off-by: Ming Liu <ming.liu@toradex.com>
The UBOOT_MAKE_TARGET is being overridden in imx-base.inc by
UBOOT_MAKE_TARGET_mx8, so the setting here is useless.
This commit makes sure the new devicetree naming is only used when
use-head-next is given in local.conf. This is necessary so one is
able to build thud-next without use-head-next.
Delete binary firmware that is no longer used.
The RT project moves the patches into an 'older' directory once superseeded
by a newer patch.
Provide both download paths to cope with the changing location.
While at it use the OE maintained KERNELORG_MIRROR variable to specify the path.
This adds a SCFW that was created with:
./create_and_deploy.sh
scfw_export_mx8qx_b0/platform/main/build_info.h:
SCFW_BRANCH imx_4.14.98_2.0.5_ga
SCFW_BUILD 3353UL
SCFW_COMMIT 0x494c97f3UL
SCFW_DATE "Aug 15 2019"
SCFW_DATE2 Aug_15_2019
SCFW_TIME "18:06:25"
Our SCFW git hash: a5af9ce
Update rt kernel recipe to use the linux-toradex_4.14-2.0.x kernel.
These files should have been deleted with commit
'bac2ba colibri-vf: drop machine'.
To support Aster carrier board.
The to be removed device trees are no longer part of the
KERNEL_DEVICETREE variable in the meta-freescale-3rdparty layer.
Avoid confusion and remove this unnecessary _remove.
The python dependency has been handled properly in OE by the following
commit 3b0b1630:
[ u-boot: Fix pylibfdt generation ]
Drop the redundant python dependency here, they would slow down u-boot
build.
For the recipes listed in EXTRA_IMAGEDEPENDS, bitbake would create a
dependency as:
| image_pn:do_image_complete -> imagedepends_pn:do_populate_sysroot
but we actually need a image task depend on the deploy tasks of
EXTRA_IMAGEDEPENDS recipes, setting EXTRA_IMAGEDEPENDS would not help
with that, so drop it, use WKS_FILE_DEPENDS instead.
Branch name: imx_4.14.98_2.0.0_ga
Build version: 3332
Commit ID: 0x0cb6f758b
Build date: May 20 2019
Build time: 10:58:51
Our SCFW git hash:
74b74e5
Colibri iMX8X now has its environment also stored in the eMMC boot area.
Deploy the same configuration as for the Apalis iMX8 also for the Colibri iMX8X.
The kernel for Apalis iMX6 now uses mmc2 as the instance for the eMMC.
Follow that.
Build version: 3332
Our SCFW git hash:
f74abf46
Re-sync defconfig which enables emulation for deprecated instructions
in ARMv8 for AArch32, enables CAN MCP251X driver, enables a generic
LVDS panel driver and disables CAAM Keystore test driver.
This depends on and deploys the distro boot script provided
by u-boot-distro-boot.
This is needed to build imx-atf version 1.5.
