Use new library libusbg with its automatic gadget configuration
service. Also enable a console on USB gadget serial port (CDC ACM)
which is ttyGS0 on device side.
When the link goes down, the DHCP service has been disabled, while
there is no corresponding functionality which enables the service
when the link goes up again. This fix is taken from systemd 217.
This removes the 3.0.15 based Kernel for Colibri VFxx.
Since some time now we use a more recent Kernel provided from the
linux-toradex-vf_3.18.bb recipe.
cross strip tool not found without this patch.
The SUMMARY variable gives a short description of the package (<72 chars).
A missing DESCRIPTION is automatically set to the content of SUMMARY.
${PN} might be extended with some magic prefix, so don't use it in SRC_URI
assignments et. al.
With dizzy we got compiler errors when compiling with the new 4.9 gcc.
The default changed to zImage so explicit set uImage for now.
While at it cleanup the recipe, remove pci from Colibri machine features.
Update to top of -next branch which also includes FEC unbind
fixes.
meta-angstrom now overrides the effect of the patch and provides the
journald.conffile in full.
To override a setting either create the file with your settings in
meta-toradex/recipes-core/systemd/systemd/journald.conf or
edit meta-angstrom/recipes-core/systemd/systemd/journald.conf.
Also update default defconfig for colibri-vf.
Update default ALSA state for WM9712 AC97 codec support on 3.18
kernel.
This patch fixes the issue of getting serial tty login at ttymxc1 (UART_B).
Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com>
The IT variant needs different RAM timings
Two last minute fixes: Default Product/Vendor ID for USB peripheral
in U-Boot and fix for the USB peripheral RNDIS freeze.
In order to make the MCC kernel module working with our newer kernel
some changes had been made on the MCC kernel module. The changes
are available on the Toradex Github account. Get the MCC kernel
module sources from Github.
Switch default kernel recipe to linux-toradex-vf which will build
a kernel based on the toradex 3.18-next branch.
Update to a U-Boot and Kernel which can be used for Apalis iMX6
HW version V1.0 and V1.1.
Also deploy additional device tree for Apalis iMX6 V1.0 modules
Add recipe to build mainline kernel. Currently, the 3.17 next branch will
be built. To use this kernel, add this lines to your local.conf
PREFERRED_PROVIDER_virtual/kernel ?= "linux-toradex"
IMAGE_INSTALL_append = "kernel-devicetree"
KERNEL_DEVICETREE += "vf500-colibri-eval-v3.dtb vf610-colibri-eval-v3.dtb"
Also, the multi-core communication packages (mqxboot, libmcc, mcc-pingpong
and kernel-module-mcc) need to be removed from recipes/images/trdx-extra.inc
since the required kernel interfaces are not available on the 3.17 mainline
port.
Angstrom started using thumb2 on machines with armv7-a architectures.
This commit removes our override to stay on arm instruction set, so
if building our machines with the angstrom distribution you now get
thumb2 builds.
Use rebased U-Boot release 2014.10. The README has a new md5sum
and U-Boots new build system has default configurations ending
with defconfig too.
Due to U-Boot udpate we need to create one big UBI volume. Since
attaching the UBI volume is the expensive operation (compared to
mount the UBIFS inside that volume), it is relatively cheep to
load the kernel directly from the root filesystems /boot directory
instead of creating a own volume for the kernel. This also makes
it simpler to load a mainline kernel (along with the required dtb
file).
However, we loose the integrity check of the uImage. But since
there were no measures in place to handle a invalid image, we do
not loose functionality here. In case we need integrity check, we
should consider switching to the new FIT image format...
meta-angstrom backported systemd 2.16 into daisy. Keep using 2.11 for now.
u-boot.inc no longer builds the standalone examples by default so
do patch to not do so is no longer needed.
The source tree will no longer be marked as git dirty.
The enlightement svn seems to be down.
Workaround by using their git repo which provides the same data
and is already used in the master branch of meta-openembedded.
Remove once we upgrade from daisy to the next stable release.
Base kernel on Freescales 3.10.17_1.0.0_ga and provide a device tree plus
code changes for Apalis iMX6.
u-boot-fw-utils allows for U-Boot environmenmt access from Linux.
Add the needed configuration file for colibri_t20 with a postinst script
which choses the right NAND flash sector sizes from /proc/mtd
While at it, fix some whitespace issues.
