2014-03-18 | u-boot Txx: update to latest | Max Krummenacher | |
2014-03-17 | kernel/u-boot: update to latest git revision | Stefan Agner | |
2014-03-17 | vybrid: backport Cortex-M utilites from meta-fsl | Stefan Agner | |
- Add utility mqxboot to load firmware into IRAM and reset M4 - Add kernel module mcc needed by libmcc - Add multi-core communication library libmcc for message queue based communication with Cortex-M core | |||
2014-02-10 | kernel/u-boot: update to latest git | Stefan Agner | |
2014-02-04 | util-linux: add fstrim | Max Krummenacher | |
Add the fstrim utility to Colibri T30 image. The utility allows to send trim commands to the underlaying flash translation layer, which allows too free not used flash sectors and those improve wear- leveling | |||
2013-12-02 | rootfs: don't populate /dev/ with static device files | Max Krummenacher | |
The Colibri VFxx console gobbles most output and sometimes provokes a kernel oops during boot, if a valid /dev/null is already part of the rootfs before mounting devtmpfs. The dynamically populated dev with devtmpfs / udev is enough. | |||
2013-12-02 | kernel: update to latest git | Max Krummenacher | |
2013-11-21 | kernel: colibri-vf: use the unified kernel 50/60 | Max Krummenacher | |
2013-11-21 | u-boot: colibri-vf: use the unified u-boot 50/61 | Max Krummenacher | |
2013-11-21 | Machine: use the changed machinename colibri-vf | Max Krummenacher | |
2013-11-21 | Machine: remove Colibri VF50, now unified with VF61 | Max Krummenacher | |
2013-11-21 | Machine: unify Colibri VF50 and Colibri VF61 | Max Krummenacher | |
2013-11-21 | Vybrid: add 'vf' to SOC_FAMILY | Max Krummenacher | |
2013-11-05 | Use double-quotes to make script work using dash (debian/ubuntu default) | Stefan Agner | |
2013-10-23 | glmark2: add missing dependencies | Max Krummenacher | |
2013-10-23 | u-boot: update to latest git version | Max Krummenacher | |
2013-10-23 | linux: update to latest git versions | Max Krummenacher | |
2013-10-17 | evdev: backport V2.8.1 from dora | Max Krummenacher | |
V2.7.3 crash when it receives multitouch events | |||
2013-10-16 | vybrid: backport from meta-fsl-arm master-next | Max Krummenacher | |
remove when moving to dora branch | |||
2013-10-16 | machines: T30 and VF50 consitstently use NEON and hard float | Max Krummenacher | |
- Colibri T30 and Apalis T30 changed to NEON - Colibri VF50 changed to hard float This makes packages built for T30 incompatible with Colibri T20 (but Colibri T20 packages can still be used on T30) | |||
2013-10-16 | chromium bbappend: add missing \ char | Max Krummenacher | |
2013-10-14 | vybrid: backport from meta-fsl-arm master-next | Max Krummenacher | |
2013-10-14 | cortex-a5.inc: backport from openembedded-core dora branch | Max Krummenacher | |
revert when moving to dora | |||
2013-10-10 | colibri-vf50: add the machine, kernel and u-boot | Max Krummenacher | |
- also add the relevant configuration files | |||
2013-10-10 | u-boot-fw-utils: add bbappend to use the same u-boot sources | Max Krummenacher | |
2013-10-07 | u-boot: clean up recipe | Max Krummenacher | |
2013-09-22 | v4l2-utils: removed patch, fixed upstream now | Max Krummenacher | |
2013-09-22 | systemd: systemd bbappend update to version 199 | Max Krummenacher | |
2013-09-22 | lxlauncher: fix FILES variable | Max Krummenacher | |
2013-09-22 | u-boot: don't build the examples | Max Krummenacher | |
- they do fail because they don't heed the private libgcc | |||
2013-09-22 | remove obsolete files | Max Krummenacher | |
2013-09-22 | systemd: follow update of recipe with bbappend | Max Krummenacher | |
2013-09-22 | x-server: add version 1.13.1 which is removed from core | Max Krummenacher | |
2013-09-22 | linux-firmware_git: remove bbappend, recipe now more granular | Max Krummenacher | |
2013-09-22 | libxi: provide dummy recipe - libxi.bbappend in a layer breaks build | Max Krummenacher | |
2013-09-22 | lxappearance-obconf: update to 0.2.0 | Max Krummenacher | |
2013-08-23 | u-boot: update to latest git version | Max Krummenacher | |
2013-06-26 | u-boot: update to latest git revision | Max Krummenacher | |
2013-06-26 | systemd: fix patch path so the default -p 1 applies | Max Krummenacher | |
2013-06-07 | systemd-journald: limit journal size | Max Krummenacher | |
2013-03-04 | remove unused files | Max Krummenacher | |
2013-02-06 | v4l-utils: fix for NULL not found erros | Max Krummenacher | |
2013-01-29 | u-boot: add Apalis-T30 | Max Krummenacher | |
- add Apalis-T30 - remove u-boot machine definition, this is also defined in the machine conf. | |||
2013-01-29 | glmark2: add recipe for linaro glmark2 | Max Krummenacher | |
2013-01-29 | alsa: add Apalis-T30 initial asound.state | Max Krummenacher | |
2013-01-29 | kernel: unified the recipes for all toradex kernels | Max Krummenacher | |
2013-01-22 | u-boot: update to latest on git.toradex.com | Max Krummenacher | |
2013-01-22 | kernel: update to latest on git.toradex.com | Max Krummenacher | |
2012-12-31 | update u-boot and kernel git versions | Max Krummenacher | |
remove testfile | |||
2012-12-18 | u-boot: remove all modification, they are moved to u-boot git | Max Krummenacher | |
