2016-03-14linux-firmware: drop bbappend, changes are now in metaMax Krummenacher
Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2016-03-14Apalis/Colibri iMX6: drop in favour of meta-fsl-arm-extraMax Krummenacher
machine/u-boot/kernel files have been added to meta-fsl-arm-extra. Use them from there now. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2016-03-14colibri-vf: read machine configuration, remove zImage from rootfsStefan Agner
Read machine configuration and remove Kernel image and device tree from rootfs since we start using static UBI volumes. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-03-14Update Vybrid U-Boot to latest versionStefan Agner
2016-03-14recipes-support: usb-suspend-resume: Add USB suspend resume fix for VybridSanchayan Maity
Add systemd service which utilises systemd's suspend resume hooks to excute scripts which take care of unbinding and binding the necessary configurations and usb driver during suspend and resume respectively. Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com> Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2015-12-15linux-firmware: backport rtl8192cx: Add latest available firmwareMax Krummenacher
Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2015-12-15Update all U-Boot versions to latestMax Krummenacher
2015-12-15linux-toradex_4.1: update to latest revisionMax Krummenacher
Update to latest revision which contains a SPI bugfix and the latest upstream stable release v4.1.15. Also synchronize the VF defconfig. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2015-12-15linux-toradex-fsl: update to latest revisionMax Krummenacher
Update to latest revision which fixes Colibri iMX6D not powerering off but creating a stacktrace. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2015-12-15linux-toradex_4.1: convert recipe to bbappendMax Krummenacher
We have this recipe in meta-fsl-arm-extra. Convert it to a bbappend and only keep the changes to the bb files. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2015-12-15Apalis iMX6: U-Boot: change name for IT modulesMax Krummenacher
Change the name form u-boot-it.imx to u-boot.imx-it. This prepares for the upcomming move of the i.MX 6 based modules BSP to meta-fsl-arm-extra. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2015-12-15README: Add README with dependency and contribution informationStefan Agner
Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2015-12-15colibri_vf: updated defconfig enables RTL8192CU driverStefan Agner
Enable RTL8192CU driver to support LM006 USB WiFi adapter. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2015-11-04Apalis/Colibri iMX6: Update Linux kernel to latestMax Krummenacher
2015-11-04linux: fix B != SMarcel Ziswiler
2015-11-04apalis/colibri_imx6/t20/t30: add version/git hash to KernelStefan Agner
Add LOCALVERSION and generate a scmversion file to annotate the Kernel with the Toradex release and a git hash.
2015-11-04apalis/colibri_imx6: update/load USB Gadget ConfigFS automaticallyStefan Agner
Since we use USB Gadget ConfigFS now use libusbg to load the USB Gadget configuration automatically.
2015-11-03Update Linux kernel and U-Boot to latest.Marcel Ziswiler
2015-10-30joe: drop recipe in favour of meta-openembeddedMax Krummenacher
meta-openembedded provides a recipe for joe, use that one.
2015-10-30chromium: remove outdated bbappendMax Krummenacher
2015-10-30apalis/colibri_imx6/t30: u-boot-fw-utils: update fw_printenv/setenvMarcel Ziswiler
Introduce/update postinst code to dynamically adjust fw_env.config and fw_unlock_mmc.sh shell profile extension script to cope with our new unified eMMC layout: boot area partition 1 aka primary eMMC boot sector: with U-Boot boot loader and the U-Boot environment before the configblock at the end of that boot area partition
2015-10-30evdev: remove old backportStefan Agner
The evdev version provided by oe-core is in the meantime newer than this backport, hence we can safely remove it.
2015-10-28machine Apalis iMX6: deploy Ixora device treesMax Krummenacher
2015-10-28machines iMX6: drop pinning of X-Server versionMax Krummenacher
2015-10-21colibri_vf: update/load USB Gadget ConfigFS automaticallyStefan Agner
Update defconfig and kernel version to latest version from git. This also configures the USB Gadget ConfigFS as a module. Add the ConfigFS module to the list of autoloaded modules.
2015-10-12Apalis iMX6: cleanup filename for V1.0 HWMax Krummenacher
Follow the rename imx6q-apalis-eval_v1_0.dtb to imx6q-apalis_v1_0-eval.dtb in the kernel. The v1_0 denotes the Apalis module version, not the evaluation board version.
2015-10-12apalis-imx6: update kernel to toradex_imx_3.14.28_1.0.0_ga-nextMax Krummenacher
2015-08-13colibri-vf: update u-boot fw-utils to latestMax Krummenacher
2015-08-13colibri-vf: update u-boot to latestMax Krummenacher
2015-08-13colibri-vf: initial kernel based on upstream 4.1Max Krummenacher
2015-08-07Revert "systemd: restore userspace firmware loading support"Max Krummenacher
This reverts commit bd2d32bf3a8460c87849e75ad01e11450d8cda10. Remove the backport, is part of fido.
2015-08-07gpu-viv-bin: package has been renamed and splitMax Krummenacher
gpu-viv-bin-mx6q -> imx-gpu-viv with a bunch of subpackages.
2015-08-07kernel: adapt to oe's new shared work dirMax Krummenacher
2015-08-07colibri-vf: use U-Boot recipe from meta-fsl-arm-extraMax Krummenacher
2015-08-07colibri-vf: moved to meta-fsl-arm, remove hereMax Krummenacher
2015-08-07alsa-state: choose extended record volumeStefan Agner
The WM9715L AC97 codec supports two volume modes for audio capturing: basic (AC97 conform) and extended. The extended range allows smaller gain steps and a large range, hence use this mode by default.
2015-06-16base-files/u-boot-toradex-fw-utils: move MMC unlockStefan Agner
The mmc unlock function causes troubles when using Poky reference distribution since Poky uses the busybox shell: /etc/rc5.d/S09xserver-nodm: /etc/profile.d/fw_unlock_mmc.sh: line 2: syntax error: unexpected "(" This avoids X getting at all. This patch does not solve the underlying problem, but works around it by moving the script to the u-boot-toradex-fw-utils recipe, which is not installed by the Poky images by default.
2015-06-03colibri_vf: enable SCSI disk required for USB mass storageStefan Agner
SCSI lock device disk support is required for USB mass storage to work. Also enable asynchronous SCSI scanning by default.
2015-05-29mcc-kmod: fix revision to build with kernel revision usedStefan Agner
Use a fixed revision of the MCC kernel module which makes sure it builds with the corresponding Vybrid Linux kernel, which also uses a fixed git hash.
2015-05-18Apalis/Colibri iMX6: use toradex_imx_3.10.17_1.0.0_ga branchMax Krummenacher
2015-05-18Apalis/Colibri: update U-Boot to latestMax Krummenacher
And use 2015.04-toradex branch
2015-05-18Colibri VF: use latest from toradex_vf_4.0 branchMax Krummenacher
2015-05-18Apalis/Colibri: update U-Boot to latest in -nextMax Krummenacher
2015-05-18Apalis/Colibri iMX6: update kernel to latest in -nextMax Krummenacher
2015-05-18Apalis iMX6 IT: u-boot: use the IT defconfig for ITMax Krummenacher
2015-05-18Revert "systemd-machine-id-commit: add standalone recipe"Max Krummenacher
Angstom Dizzy now uses systemd V218 so there is no need to build a component seperately anymore. This reverts commit 16b8b392ad048566729f30d7c3887d1bfdf21bd4.
2015-05-18machines: don't pin systemd version anymoreMax Krummenacher
Use systemd V2.18 from meta-angstrom. Issues with firmware loading and the 3.1.10 kernel for the tegra machines are fixed with a backport from oe-core.
2015-05-18systemd: restore userspace firmware loading supportJonathan Liu
This changes the minimum required Linux version from 3.7 back to 3.0. [YOCTO #7409] Signed-off-by: Jonathan Liu <net147@gmail.com> Signed-off-by: Richard Purdie <richard.purdie@linuxfoundation.org> backported from openembedded-core, commit 31163abc7bedd477c1aad10e6d1f47dbee194513
2015-05-18Revert "systemd: fix DHCP on link state change"Max Krummenacher
This reverts commit 3cf2edb10f5e8ac60db7ca2e71d1e754a177d08c. Conflicts: recipes-core/systemd/systemd_%.bbappend
2015-05-12colibri-vf: remove ext2 from MACHINE_FEATURESMax Krummenacher
