Without this the default fw_env.config gets deployed.
Otherwise packages that have a run-time dependency on u-boot-fw-utils
will not build u-boot-toradex-fsl-fw-utils and instead use the
"default" one.
This was observed when layer is used together with poky.
Signed-off-by: Mirza Krak <mirza.krak@gmail.com>
Enable Toradex Easy Installer image for Colibri iMX6 machine. This
requires to specify the Product Id this machine supports so that
the Installer can filter the images and only show images compatible
with the module currently running on.
Requesting a 16 bit default depth lead to a inconsistency between
X-Server and DRM drivers bpp setting. This is the default configuration
for Vybrid. Add a patch fixing the issue.
Image formats which include the U-Boot binary rely on U_BOOT_BINARY
pointing to a U-Boot binary working with SPL. U_BOOT_BINARY seems
to point to the last U-Boot binary built, hence move the "spl"
configuration to the end to make sure U_BOOT_BINARY points to the
U-Boot binary which works with SPL.
Enable Toradex Easy Installer image for Apalis iMX6 machine. This
This kernels are based on the fslc community kernel which in turn are
based on the NXP 4.1.15 released kernels.
They can be used for Apalis iMX6, Colibri iMX6, and Colibri iMX7.
0001-fw_env.c-include-stdint.h-unconditionally.patch has been fixed upstream.
This provides an alternative to packagegroup-fsl-tools-gpu which installs
examples and tools which pull in also the libraries but blows up image
size.
fix errors due to missing uint* types.
Move to u-boot git.
Kernel upgraded to 3.14.52 kernel.
SIT tunnels (IPv6 over IPv4) are not often used hence configure
the driver as a module. This also gets rid of the extra network
interface sit0 by default.
Add default xorg.conf for Vybrid based modules. This makes sure that
the DRM enabled modesetting DDX driver gets used.
Auto-load rpmsg/remoteproc modules during boot.
Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com>
Update defconfig to build rpmsg and remoteproc.
Synchronize defconfig with kernel git.
The DRM driver fbdev emulation does not support setting modes
using fbset:
ioctl FBIOPUT_VSCREENINFO: Invalid argument
Remove the fb.modes configuration file as it provides no value
anymore.
Move the appends on recipe's which are not in an essential required layer
into a target layer specific directory and add them only if said layer
is active in build/conf/bblayers.conf.
Do not use the function keyword, then the script works fine with
with Busybox' shell implementation.
While we use only one erase block for the U-Boot environment, we
reserve four in case there are bad blocks in the environment area.
Specify the number of blocks so that the Linux utilities are able
to read/write the environment even if the first block of the
environment is bad.
Rely on newly implemented configuration functionality to locate the
environment at the end of the boot partition.
