The patch 0003-Remove-check-for-useSIGIO-option.patch has been added to
xorg-server recipe on meta-freescale layer [1].
Reapplying this patch causes the build error [2].
Remove this patch from the meta-toradex-nxp layer.
[1]
07d4a6baa23ec3a1f013f8a070130598b56aec7c
xserver-xorg: Backport to fix X server 1.20.1 crash [YOCIMX-3280]
[2]
ERROR: xserver-xorg-2_1.20.1-r0 do_patch: Command Error: 'quilt --quiltrc
/oe-core/build/tmp/work/armv7at2hf-neon-mx6qdl-tdx-linux-gnueabi/
xserver-xorg/2_1.20.1-r0/recipe-sysroot-native/etc/quiltrc push'
exited with 0 Output:
Patch 0003-Remove-check-for-useSIGIO-option.patch is already applied; check your series file
Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
Basically, as per the following commit from the
toradex_4.14-2.3.x-imx branch on git://git.toradex.com/linux-toradex.git
ab66d6c48c8e78e74ebbf41505db65b0830e6fd7
ARM: apalis/colibri-imx6/7/6ull: enable options for backports
8d6cc5a3e9a2cf349c4d42e13c4449f16512651e
ARM: apalis/colibri-imx6/7/6ull: disable wireless drivers
c666f52447fa426fdc414bb1c922d89969f25385
arm64: defconfig: enable options required for backports
d55c4e1ff7f1a6b23908d45bfec48b2c717d13fe
arm64: defconfig: disable wireless drivers
Related-to: ELB-2687
19a90652d70208c755d3339e21f6bfc8cae04b82:
ARM: apalis/colibri: defconfig: remove backported drivers
76b17e9c0b6f0245dc76c59062257bea2d0d6a0f:
arm64: apalis/colibri: defconfig: remove backported drivers
Related-to: ELB-2388
Related-to: ELB-2510
Resync with latest configs in the kernel, but switch on PREEMPT_RT_FULL.
Use the latest binaries provided for Toradex boards.
Final synchronization with the commit from the toradex_4.14-2.3.x-imx
branch on git://git.toradex.com/linux-toradex.git:
25c008952d3a61c9c402126d4ba7424ef8132f90
arm64: defconfig: further config clean-up
Basically, as per the following commit from the toradex_4.14-2.3.x-imx
b1df9c77a53e92dc6b993007e3d8bb1f3cc61bf6:
colibri imx6ull: defconfig: enable building backports-5.4
Basically, as per the following two commits from the
ad4d419f1b24e1d986e2fe956c1f3ca7d1eab93f:
apalis/colibri_imx6/-imx6ull/_imx7/-imx8/8x_defconfig: config refresh
Note that currently the Toradex Easy Installer does nothing with the
TORADEX_PRODUCT_IDS[0055] setting on eMMC machines.
Related-to: ELB-2322
Drop the upstreamed machine configuration file and move all differences
into conf/machine/include/colibri-imx6ull.inc.
Deploy additional device trees.
Related-to: ELB-2593
Any fixups not upstreamed should be done here:
conf/machine/include/apalis-imx6.inc
This reverts commit 007649356c8db93ce09c766f4b46ccfaae7025a3.
This fixes a following compiling error on verdin-imx8mm machine:
+| plat/imx/common/imx8m/imx_rdc.c: In function 'imx_rdc_set_masters':
+| plat/imx/common/imx8m/imx_rdc.c:146:9: error: 'ret' may be used uninitialized in this function [-Werror=maybe-uninitialized]
Signed-off-by: Ming Liu <ming.liu@toradex.com>
Related-to: ELB-1254
Thus they are stored in one place and also apply to i.MX6/i.MX7 machines
should one build them for wayland/weston.
Related-to: ELB-2303
For apalis-imx8 this makes gst-play and the gstreamer playbin plugin
automatically convert the tiling output of the vpu decoder to the
video sink plugins requirement.
Related-to: ELB-2351
This provides headers unique to the NXP downstream kernel.
Since linux-toradex is rebased onto NXP's downstream kernel the needed
git hash is also part of our linux-toradex git and we can save the
download of a second kernel git repo.
This updates to the NXP BSP 2.3.0 at tag rel_imx_4.14.98_2.3.1_patch.
The seco firmware is now split out of firmware-imx.
The seco firmware has now a i.MX8X B0 and C0 silicon version.
Update to version based on NXP SCFW 1.3.1.
Branch name: imx_4.14.98_2.3.0
Build version: 4124
Commit ID: 0x0b929edfe
Build date: Jan 31 2020
Build time: 21:06:48
This fixes a problem of tezi fitimage not boot issue.
Related-to: TEI-498
In order to build the scfw recipe the NXP EULA must be accepted.
Enforce acceptence with the fsl-eula-unpack class mechanisms.
Related-to: ELB-1252
- Set git hash to latest binary build.
- With use-head-next override, now take latest HEAD of the imx-sc-firmware.
Related-to: ELB-2333
Add UBOOT_ENTRYPOINT and UBOOT_RD_LOADADDRESS which are needed by
fitimage.
That's already handled by WKS_FILE_DEPENDS, drop the redundant
dependencies.
u-boot-toradex-common.inc: all but below
u-boot-toradex-common_2018.03.inc: i.MX 8 series based modules
u-boot-toradex_2016.11.bbappend: Toradex Easy Installer 2.0
linux-toradex_4.14-2.0.x.bb: all NXP based modules
Resync with the defconfigs from the kernel repository. This adds:
- fix ip firewall (bpf/cgroup)
- Revert "arm64: defconfig: Choose the newer version of the ov5640 driver"
This gives the codec reasonable mixer defaults.
Without this a getty on the non existing ttyS0 gets additionally started
which then fails and gets continously restarted.
