Drop the upstreamed machine configuration file and move all differences
into conf/machine/include/colibri-imx6ull.inc.
Deploy additional device trees.
Related-to: ELB-2593
This allows to use u-boot-fw-utils in image recipes.
Our downstream U-Boot provides a u-boot-nand.imx target prepending the
binary with a 1k block for easier flashing while the mainline U-Boot
does not.
Mimic the behaviour in a do_compile_append.
With the move to use '+=' in the assignment the parsing order of the
files matters, as assignments with '=' will delete all previously
parsed '+=' assignments.
Change all assignments to '+='.
SERIAL_CONSOLE has been deprecated for a while now.
While at it, move from ?= to a = assignment. Since imx-base.inc already
definces SERIAL_CONSOLES using ?= makes no sense.
The kernel class now sets RDEPENDS_${KERNEL_PACKAGE_NAME}-base so this include
needs to do the same, otherwise bitbake emits a warning and the kernel isn't
removed.
Device trees for the carrier board Aster are now available, deploy
them.
Build and deploy the device tree for the Colibri iMX6ULL 512MB Wi-Fi / BT.
The kernel lives in its own ubi volume. Save the space in the rootfs.
Use u-boot-nand.imx which has a 1kB padding so it can be written
directly to flash.
Add support for Toradex Easy Installer by specifying Toradex
product ids and flash type.
