Switch default kernel recipe to linux-toradex-vf which will build
a kernel based on the toradex 3.18-next branch.
Angstrom started using thumb2 on machines with armv7-a architectures.
This commit removes our override to stay on arm instruction set, so
if building our machines with the angstrom distribution you now get
thumb2 builds.
Use rebased U-Boot release 2014.10. The README has a new md5sum
and U-Boots new build system has default configurations ending
with defconfig too.
Due to U-Boot udpate we need to create one big UBI volume. Since
attaching the UBI volume is the expensive operation (compared to
mount the UBIFS inside that volume), it is relatively cheep to
load the kernel directly from the root filesystems /boot directory
instead of creating a own volume for the kernel. This also makes
it simpler to load a mainline kernel (along with the required dtb
file).
However, we loose the integrity check of the uImage. But since
there were no measures in place to handle a invalid image, we do
not loose functionality here. In case we need integrity check, we
should consider switching to the new FIT image format...
meta-angstrom backported systemd 2.16 into daisy. Keep using 2.11 for now.
Angstrom default on armv7a would be thumb2, however there are some
recipes around with arm assembler which fails.
If the package manager finds a version newer than the prefered-version that one
gets installed. As we need a specific one for the tegras and for imx6 we
change the 'epoch' to something very high.
unify the features between machines
kernel26 is deprecated and unused
apm does not make sense on ARM
While at it remove some commented stuff
This commit switches Colibri VF machine to use the 2014.04 git
branch. The change to latest U-Boot brings proper NAND hardware
ECC support, which is also enabled in latest Linux kernel.
Beside that, burnflash is updated to correctly work with the
new U-Boot version and the altered Config Block location.
remove the files copied from meta-fsl* for Colibri-VF V2.1
move the colibri-vf u-boot and kernel stuff to meta-fsl-arm-extra
The Colibri VFxx console gobbles most output and sometimes
provokes a kernel oops during boot, if a valid /dev/null
is already part of the rootfs before mounting devtmpfs.
The dynamically populated dev with devtmpfs / udev is enough.
