For the recipes listed in EXTRA_IMAGEDEPENDS, bitbake would create a
dependency as:
| image_pn:do_image_complete -> imagedepends_pn:do_populate_sysroot
but we actually need a image task depend on the deploy tasks of
EXTRA_IMAGEDEPENDS recipes, setting EXTRA_IMAGEDEPENDS would not help
with that, so drop it, use WKS_FILE_DEPENDS instead.
Signed-off-by: Ming Liu <ming.liu@toradex.com>
This depends on and deploys the distro boot script provided
by u-boot-distro-boot.
Update to a 2019.07 based U-Boot.
Use the openembedded master recipes for u-boot_2019.07 as a base.
This makes the u-boot recipe in recipes-bsp/u-boot-mainline/ obsolete,
delete it.
Provide the MACHINE_NAME variable which can be e.g. used as part of the
image name.
Use for all Toradex machines exept apalis-imx8 a mainline based U-Boot.
(For the i.MX8QM mainline is not yet able to boot the kernel)
According to the Yocto manual v.2.6.1
(https://www.yoctoproject.org/docs/2.6.1/mega-manual/mega-manual.html#var-IMAGE_FSTYPES):
Due to the way the OpenEmbedded build system processes this variable, you
cannot update its contents by using _append or _prepend. You must use the +=
operator to add one or more options to the IMAGE_FSTYPES variable.
Signed-off-by: Gerard Salvatella <gerard.salvatella@toradex.com>
Actually make use of them various upgrades.
This is required since meta-freescale commit a4158e3425a7
("gstreamer1.0: Set DEFAULT_PREFERENCE as -1 to imx version") et. al.
and is analogous to meta-freescale-distro commit 29e7a3d322c7
("fsl-base.inc: Set PREFERRED_VERSION for Gstreamer to use i.MX Version"
Colibri iMX6ULL and Colibri iMX7 were added as according to the i.MX
Reference Manual L4.1.15_2.1.0-ga they at least could profit from the
Pixel Pipeline (PxP) DMA-ENGINE driver.
These modules to not have the epdc IP, so there is no need to deploy the
large firmware files.
