Add the following additional SKU product ids which are compatible
with the verdin-imx8mm machines.
0059: Verdin iMX8M Mini Quad 2GB IT
0060: Verdin iMX8M Mini DualLite 1GB WB IT
Related-to: ELB-3128
(cherry picked from commit 47ee60494d3d6579e2aaa5739ea515fcd86e6b90)
E.g. generating a fitimage for the Toradex Easy Installer will use those
addresses. Unfortunately, in the Verdin iMX8M Mini DualLite 1GB case,
there is no memory at 0x80280000 resp. 0xA0000000 so we need to move
them within its 1GB address space (e.g. below 0x80000000).
Note that currently the Toradex Easy Installer does nothing with the
TORADEX_PRODUCT_IDS[0055] setting on eMMC machines.
Related-to: ELB-2322
Thus they are stored in one place and also apply to i.MX6/i.MX7 machines
should one build them for wayland/weston.
Related-to: ELB-2303
Add UBOOT_ENTRYPOINT and UBOOT_RD_LOADADDRESS which are needed by
fitimage.
Signed-off-by: Ming Liu <ming.liu@toradex.com>
That's already handled by WKS_FILE_DEPENDS, drop the redundant
dependencies.
Without this a getty on the non existing ttyS0 gets additionally started
which then fails and gets continously restarted.
