Note that currently the Toradex Easy Installer does nothing with the
TORADEX_PRODUCT_IDS[0055] setting on eMMC machines.
Related-to: ELB-2322
Drop the upstreamed machine configuration file and move all differences
into conf/machine/include/colibri-imx6ull.inc.
Deploy additional device trees.
Related-to: ELB-2593
Any fixups not upstreamed should be done here:
conf/machine/include/apalis-imx6.inc
This reverts commit 007649356c8db93ce09c766f4b46ccfaae7025a3.
Related-to: ELB-1254
Thus they are stored in one place and also apply to i.MX6/i.MX7 machines
should one build them for wayland/weston.
Related-to: ELB-2303
The seco firmware is now split out of firmware-imx.
The seco firmware has now a i.MX8X B0 and C0 silicon version.
Related-to: ELB-2351
This fixes a problem of tezi fitimage not boot issue.
Related-to: TEI-498
Signed-off-by: Ming Liu <ming.liu@toradex.com>
Add UBOOT_ENTRYPOINT and UBOOT_RD_LOADADDRESS which are needed by
fitimage.
That's already handled by WKS_FILE_DEPENDS, drop the redundant
dependencies.
Without this a getty on the non existing ttyS0 gets additionally started
which then fails and gets continously restarted.
This reverts commit e3e5aba1c725ad3ff4daf128ad525625923a653d.
The UBOOT_MAKE_TARGET is being overridden in imx-base.inc by
UBOOT_MAKE_TARGET_mx8, so the setting here is useless.
This commit makes sure the new devicetree naming is only used when
use-head-next is given in local.conf. This is necessary so one is
able to build thud-next without use-head-next.
To support Aster carrier board.
The to be removed device trees are no longer part of the
KERNEL_DEVICETREE variable in the meta-freescale-3rdparty layer.
Avoid confusion and remove this unnecessary _remove.
For the recipes listed in EXTRA_IMAGEDEPENDS, bitbake would create a
dependency as:
| image_pn:do_image_complete -> imagedepends_pn:do_populate_sysroot
but we actually need a image task depend on the deploy tasks of
EXTRA_IMAGEDEPENDS recipes, setting EXTRA_IMAGEDEPENDS would not help
with that, so drop it, use WKS_FILE_DEPENDS instead.
This depends on and deploys the distro boot script provided
by u-boot-distro-boot.
This allows to use u-boot-fw-utils in image recipes.
Update to a 2019.07 based U-Boot.
Use the openembedded master recipes for u-boot_2019.07 as a base.
This makes the u-boot recipe in recipes-bsp/u-boot-mainline/ obsolete,
delete it.
Since we changed the machine configuration name, follow with the description
and the prefix to the image names.
Add the product numbers of additional Colibri iMX8X SKUs.
Add the product numbers of additional Apalis iMX8 SKUs.
For apalis-imx8 we use the family name. Unify that for colibri-imx8x.
Related to: #49287
mainline currently does not provide the ums command. Without the
Toradex Easy Installer this hinders development.
This reverts commit a7f384f for colibri-imx8qxp.conf.
The device ttyAMA1 stems from ARM AMBA pl011 driver. On i.MX 8 we do
not have such an IP, hence this device does not exist.
The variable assignment and comment has been copied from NXP machines
and they seem to have copied it from other machines.
Use the now available MACHINE_BOOT_FILES variable to deploy the HDMI
firmware into the boot partition.
imx-boot needs that, but it is currently only added to the host tools
if building for i.MX8X.
Provide the MACHINE_NAME variable which can be e.g. used as part of the
image name.
Add information required to build a Toradex Easy Installer image.
Only support the main SKU Colibri iMX8 QuadXPlus 2GB Wi-Fi / BT IT
for now since we do not know yet if the other SKU's need a special
device tree or other adjustments.
Only support the main SKU Apalis iMX8 QuadMax 4GB Wi-Fi / BT IT
Our downstream U-Boot provides a u-boot-nand.imx target prepending the
binary with a 1k block for easier flashing while the mainline U-Boot
does not.
Mimic the behaviour in a do_compile_append.
