Signed-off-by: Tom Hochstein <tom.hochstein@nxp.com>
If the user defines the machine to build in local.conf the
environment variable ${MACHINE} is not available when
conf/layer.conf gets parsed. Remove the include in favor of
including from local.conf.
Include a file to the machine configuration to amend to the upstream
$MACHINE.conf file.
Add a inc file to allow downstream specific amendments.
Currently used to inject Toradex Easy Installer image creation.
Build and deploy the device tree for the Colibri iMX6ULL 512MB Wi-Fi / BT.
The kernel lives in its own ubi volume. Save the space in the rootfs.
Prepare for configurable boot ROM and SPL payload offsets to be applied
to resp. image.json for Toradex Easy Installer.
Use u-boot-nand.imx which has a 1kB padding so it can be written
directly to flash.
Add support for Toradex Easy Installer by specifying Toradex
product ids and flash type.
Building device tree with a dot in the file name leads to following
ERROR: console-tdx-image-2.7b3-r0 do_image_sdcard: imx6q-apalis-ixora-v1.1.dtb does not exist.
ERROR: console-tdx-image-2.7b3-r0 do_image_sdcard: Function failed: do_image_sdcard
Temporarily remove until we have support for dots in device tree files:
https://github.com/Freescale/meta-freescale/commit/ce1e0af209c222cb877962104c4f807d5807fa1e
Add new machine file for Colibri iMX7 Dual 1GB (eMMC) modules.
Ixora V1.1
Add Ixora V1.1 device tree to Apalis iMX6 OE machine configuration.
Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com>
As somebody previously decided to rename U_BOOT_BINARY to UBOOT_BINARY
unbreak e.g. i.MX 6 Tezi builds by continuing that rename through the
various layers:
http://git.toradex.com/cgit/meta-toradex-bsp-common.git/commit/?h=morty&id=02f7fdfe5eaca64e0c710cce4d701a609d499e8b
Add machine definition for Vybrid. The Vybrid machine definition
is already present in meta-freescale-3rdparty. Add the same to
the meta-toradex-nxp layer to be able to deploy Aster device
trees.
Add Aster device tree to Colibri iMX6 OE machine configuration.
Add Aster device tree to Colibri iMX7 OE machine configuration.
Add Toradex Easy Installer support by enabling the tezi image
format. Also specify the Product IDs this machine is compatible
with and the device tree associated with them. This is used on
devices where we have variants using different device trees but
were built using a single OpenEmbedded machine.
In our images this has been done during do_rootfs and friends,
do it the oe-core way.
While at it clean-up and unify with other Toradex layers.
The "tezi" image type has been renamed to "teziimg".
Enable Toradex Easy Installer image for Colibri iMX6 machine. This
requires to specify the Product Id this machine supports so that
the Installer can filter the images and only show images compatible
with the module currently running on.
Image formats which include the U-Boot binary rely on U_BOOT_BINARY
pointing to a U-Boot binary working with SPL. U_BOOT_BINARY seems
to point to the last U-Boot binary built, hence move the "spl"
configuration to the end to make sure U_BOOT_BINARY points to the
U-Boot binary which works with SPL.
Enable Toradex Easy Installer image for Apalis iMX6 machine. This
Remove Kernel image and device tree from rootfs since we start using
static UBI volumes.
Fix build failure because mqxboot_2.x is built instead of the
required mqxboot_1.x.
The mqxboot version changed from 1.0 to 1.0.1.
Choosing the preferred version with a wildcard prevents using
the not compatible 2.x version.
NOTE: preferred version 1.0 of mqxboot not available (for item mqxboot)
NOTE: versions of mqxboot available: 1.0.1 2.0.1
While at it set the prefered providers for mcc related recipes.
(ported from meta-fsl-arm-extra 6eefe6562d51525ff511adf81a84ad7af8a25814
and 0f4942175f8ae00741b2fee2ab82ceedb58f15c3)
The Toradex Colibri iMX7 computer module is based on i.MX 7.
The Colibri iMX7 is a member of the pincompatible Colibri family.
They feature on module RAM and NAND, Ethernet PHY, Resistive Touch
Controller and Audio Codec.
For additional specifications please visit:
https://www.toradex.com/computer-on-modules/colibri-arm-family/freescale-imx7
machine/u-boot/kernel files have been added to meta-fsl-arm-extra.
Use them from there now.
Read machine configuration and remove Kernel image and device tree
from rootfs since we start using static UBI volumes.
Follow the rename imx6q-apalis-eval_v1_0.dtb to imx6q-apalis_v1_0-eval.dtb
in the kernel.
The v1_0 denotes the Apalis module version, not the evaluation board version.
Use systemd V2.18 from meta-angstrom.
Issues with firmware loading and the 3.1.10 kernel for the tegra machines
are fixed with a backport from oe-core.
Also deploy an additional device tree supporting a Colibri iMX6 with
Analog Camera Module.
Use new library libusbg with its automatic gadget configuration
service. Also enable a console on USB gadget serial port (CDC ACM)
which is ttyGS0 on device side.
The default changed to zImage so explicit set uImage for now.
While at it cleanup the recipe, remove pci from Colibri machine features.
This patch fixes the issue of getting serial tty login at ttymxc1 (UART_B).
Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com>
Switch default kernel recipe to linux-toradex-vf which will build
a kernel based on the toradex 3.18-next branch.
