path: root/conf
2018-03-29colibri-imx7: add Colibri iMX7D 512MB EPDC SKUStefan Agner
The same device tree as the regular Colibri iMX7D SKU uses can be used. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2018-03-29apalis/colibri imx6: switch to zimage instead of uimageMax Krummenacher
Switch to the generic compressed Kernel image type (zImage) instead of the U-Boot specific uImage format. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2018-03-23u-boot-toradex: drop building a recovery u-bootMax Krummenacher
We move to use SPL/u-boot.img also in the recovery case. Drop building the u-boot-recover.imx and no longer rename the u-boot-spl.img file to the misleading name u-boot-spl.imx. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-12-23apalis/colibri imx: don't deploy the epdc firmwareMax Krummenacher
These modules to not have the epdc IP, so there is no need to deploy the large firmware files. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-12-23imx-gpu-g2d: Move imx-gpu-g2d out of imx-gpu-viv v6Tom Hochstein
Signed-off-by: Tom Hochstein <tom.hochstein@nxp.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-12-23layer.conf: remove machine includeStefan Agner
If the user defines the machine to build in local.conf the environment variable ${MACHINE} is not available when conf/layer.conf gets parsed. Remove the include in favor of including from local.conf. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-12-23apalis-imx6: remove no longer existing Apalis iMX6 V1.0 dtsStefan Agner
2017-12-23layer.conf: apply an include to machine.confMax Krummenacher
Include a file to the machine configuration to amend to the upstream $MACHINE.conf file. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-12-23colibri-vf.conf: upstream to meta-freescale-3rdpartyMax Krummenacher
2017-12-23machines: upstream changes for 2.7.4 imageMax Krummenacher
Add a inc file to allow downstream specific amendments. Currently used to inject Toradex Easy Installer image creation. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-12-22colibri-imx6ull: prepare for upstreaming to fslcMax Krummenacher
2017-12-22colibri-imx7-emmc: prepare for upstreaming to fslcMax Krummenacher
2017-11-27colibri-imx6ull.conf: add dtb for wifi variantMax Krummenacher
Build and deploy the device tree for the Colibri iMX6ULL 512MB Wi-Fi / BT. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com>
2017-10-04colibri-imx6ull: don't deploy the epdc firmwareColibri-iMX7_LXDE-Image_2.7b4-20171005Colibri-iMX6_LXDE-Image_2.7b4-20171005Colibri-VF_LXDE-Image_2.7b4-20171005Apalis-iMX6_LXDE-Image_2.7b4-20171005Max Krummenacher
2017-10-04colibri-imx6ull: don't deploy the kernel in the rootfsMax Krummenacher
The kernel lives in its own ubi volume. Save the space in the rootfs. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com>
2017-10-03apalis/colibri-imx6.conf/colibri-imx7-emmc.conf: payload offsetsMarcel Ziswiler
Prepare for configurable boot ROM and SPL payload offsets to be applied to resp. image.json for Toradex Easy Installer. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com>
2017-10-03colibri-imx6ull: use U-Boot with 1kB paddingStefan Agner
Use u-boot-nand.imx which has a 1kB padding so it can be written directly to flash. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-10-03colibri-imx6ull: add Toradex Easy Installer supportStefan Agner
Add support for Toradex Easy Installer by specifying Toradex product ids and flash type. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-10-03colibri-imx6ull.conf: add machineMax Krummenacher
2017-10-03apalis-imx6.conf: remove sdcard.gz image typeMax Krummenacher
Building device tree with a dot in the file name leads to following messages: ERROR: console-tdx-image-2.7b3-r0 do_image_sdcard: imx6q-apalis-ixora-v1.1.dtb does not exist. ERROR: console-tdx-image-2.7b3-r0 do_image_sdcard: Function failed: do_image_sdcard Temporarily remove until we have support for dots in device tree files: https://github.com/Freescale/meta-freescale/commit/ce1e0af209c222cb877962104c4f807d5807fa1e Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com>
2017-10-03colibri-imx7-emmc: add machine for Colibri iMX7 Dual 1GB (eMMC)Stefan Agner
Add new machine file for Colibri iMX7 Dual 1GB (eMMC) modules. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-10-03conf: machine: apalis-imx6: Deploy Apalis iMX 6 device tree tailored to ↵Sanchayan Maity
Ixora V1.1 Add Ixora V1.1 device tree to Apalis iMX6 OE machine configuration. Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com> Acked-by: Stefan Agner <stefan.agner@toradex.com>
2017-07-01conf: machine: apalis/colibri-imx6: rename U_BOOT_BINARY to UBOOT_BINARYColibri-iMX7_LXDE-Image_2.7b3-20170630Colibri-iMX6_LXDE-Image_2.7b3-20170630Colibri-VF_LXDE-Image_2.7b3-20170630Apalis-iMX6_LXDE-Image_2.7b3-20170630Marcel Ziswiler
As somebody previously decided to rename U_BOOT_BINARY to UBOOT_BINARY unbreak e.g. i.MX 6 Tezi builds by continuing that rename through the various layers: http://git.toradex.com/cgit/meta-toradex-bsp-common.git/commit/?h=morty&id=02f7fdfe5eaca64e0c710cce4d701a609d499e8b Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Dominik Sliwa <dominik.sliwa@toradex.com>
2017-07-01conf: machine: colibri-vf: add machine definition for vybridSanchayan Maity
Add machine definition for Vybrid. The Vybrid machine definition is already present in meta-freescale-3rdparty. Add the same to the meta-toradex-nxp layer to be able to deploy Aster device trees. Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-07-01conf: machine: colibri-imx6: add aster device tree to colibri imx6 machineSanchayan Maity
Add Aster device tree to Colibri iMX6 OE machine configuration. Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-07-01conf: machine: colibri-imx7: add aster device tree to colibri imx7 machineSanchayan Maity
Add Aster device tree to Colibri iMX7 OE machine configuration. Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-06-09colibri-imx7: add toradex easy installer supportStefan Agner
Add Toradex Easy Installer support by enabling the tezi image format. Also specify the Product IDs this machine is compatible with and the device tree associated with them. This is used on devices where we have variants using different device trees but were built using a single OpenEmbedded machine. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-04-07machine configs: don't deploy the kernel in /bootMax Krummenacher
In our images this has been done during do_rootfs and friends, do it the oe-core way. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-04-07layer.conf: add layer dependenciesMax Krummenacher
While at it clean-up and unify with other Toradex layers. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-02-08colibri/apalis-imx6: follow renaming of tezi image typeStefan Agner
The "tezi" image type has been renamed to "teziimg". Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-01-10colibri-imx6: enable Toradex Easy Installer imageStefan Agner
Enable Toradex Easy Installer image for Colibri iMX6 machine. This requires to specify the Product Id this machine supports so that the Installer can filter the images and only show images compatible with the module currently running on. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-01-09apalis/colibri-imx6: reorder U-Boot binaries to fix sdcard/tezi imageStefan Agner
Image formats which include the U-Boot binary rely on U_BOOT_BINARY pointing to a U-Boot binary working with SPL. U_BOOT_BINARY seems to point to the last U-Boot binary built, hence move the "spl" configuration to the end to make sure U_BOOT_BINARY points to the U-Boot binary which works with SPL. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-01-09apalis-imx6: enable Toradex Easy Installer imageStefan Agner
Enable Toradex Easy Installer image for Apalis iMX6 machine. This requires to specify the Product Id this machine supports so that the Installer can filter the images and only show images compatible with the module currently running on. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-01-09apalis/colibri imx6: add machines which build a spl u-bootMax Krummenacher
2017-01-09colibri-vf: machine conf updated in meta-fsl-arm-extraMax Krummenacher
2017-01-09colibri-imx7: machine conf moved to meta-fsl-arm-extraMax Krummenacher
2016-09-28add layer.confMax Krummenacher
2016-06-30colibri-imx7: add kernel 4.1.15 recipeMax Krummenacher
Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2016-06-30colibri-imx7: remove zImage and dtbs from rootfsStefan Agner
Remove Kernel image and device tree from rootfs since we start using static UBI volumes. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2016-03-30colibri-vf.conf: set mqxboot version with wildcardMax Krummenacher
Fix build failure because mqxboot_2.x is built instead of the required mqxboot_1.x. The mqxboot version changed from 1.0 to 1.0.1. Choosing the preferred version with a wildcard prevents using the not compatible 2.x version. NOTE: preferred version 1.0 of mqxboot not available (for item mqxboot) NOTE: versions of mqxboot available: 1.0.1 2.0.1 While at it set the prefered providers for mcc related recipes. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> (ported from meta-fsl-arm-extra 6eefe6562d51525ff511adf81a84ad7af8a25814 and 0f4942175f8ae00741b2fee2ab82ceedb58f15c3)
2016-03-14colibri-imx7: add machine configurationMax Krummenacher
The Toradex Colibri iMX7 computer module is based on i.MX 7. The Colibri iMX7 is a member of the pincompatible Colibri family. They feature on module RAM and NAND, Ethernet PHY, Resistive Touch Controller and Audio Codec. For additional specifications please visit: https://www.toradex.com/computer-on-modules/colibri-arm-family/freescale-imx7 Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2016-03-14Apalis/Colibri iMX6: drop in favour of meta-fsl-arm-extraMax Krummenacher
machine/u-boot/kernel files have been added to meta-fsl-arm-extra. Use them from there now. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2016-03-14colibri-vf: read machine configuration, remove zImage from rootfsStefan Agner
Read machine configuration and remove Kernel image and device tree from rootfs since we start using static UBI volumes. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2015-10-28machine Apalis iMX6: deploy Ixora device treesMax Krummenacher
2015-10-28machines iMX6: drop pinning of X-Server versionMax Krummenacher
2015-10-12Apalis iMX6: cleanup filename for V1.0 HWMax Krummenacher
Follow the rename imx6q-apalis-eval_v1_0.dtb to imx6q-apalis_v1_0-eval.dtb in the kernel. The v1_0 denotes the Apalis module version, not the evaluation board version.
2015-08-07colibri-vf: moved to meta-fsl-arm, remove hereMax Krummenacher
2015-05-18machines: don't pin systemd version anymoreMax Krummenacher
Use systemd V2.18 from meta-angstrom. Issues with firmware loading and the 3.1.10 kernel for the tegra machines are fixed with a backport from oe-core.
2015-05-12colibri-vf: remove ext2 from MACHINE_FEATURESMax Krummenacher
2015-05-12Apalis/Colibri iMX6: kernel/U-Boot update to latest in -nextMax Krummenacher
Also deploy an additional device tree supporting a Colibri iMX6 with Analog Camera Module.
