To support Aster carrier board.
Signed-off-by: Ming Liu <ming.liu@toradex.com>
The to be removed device trees are no longer part of the
KERNEL_DEVICETREE variable in the meta-freescale-3rdparty layer.
Avoid confusion and remove this unnecessary _remove.
For the recipes listed in EXTRA_IMAGEDEPENDS, bitbake would create a
dependency as:
| image_pn:do_image_complete -> imagedepends_pn:do_populate_sysroot
but we actually need a image task depend on the deploy tasks of
EXTRA_IMAGEDEPENDS recipes, setting EXTRA_IMAGEDEPENDS would not help
with that, so drop it, use WKS_FILE_DEPENDS instead.
This depends on and deploys the distro boot script provided
by u-boot-distro-boot.
This allows to use u-boot-fw-utils in image recipes.
Update to a 2019.07 based U-Boot.
Use the openembedded master recipes for u-boot_2019.07 as a base.
This makes the u-boot recipe in recipes-bsp/u-boot-mainline/ obsolete,
delete it.
Since we changed the machine configuration name, follow with the description
and the prefix to the image names.
Add the product numbers of additional Colibri iMX8X SKUs.
Add the product numbers of additional Apalis iMX8 SKUs.
For apalis-imx8 we use the family name. Unify that for colibri-imx8x.
Related to: #49287
mainline currently does not provide the ums command. Without the
Toradex Easy Installer this hinders development.
This reverts commit a7f384f for colibri-imx8qxp.conf.
The device ttyAMA1 stems from ARM AMBA pl011 driver. On i.MX 8 we do
not have such an IP, hence this device does not exist.
The variable assignment and comment has been copied from NXP machines
and they seem to have copied it from other machines.
Use the now available MACHINE_BOOT_FILES variable to deploy the HDMI
firmware into the boot partition.
imx-boot needs that, but it is currently only added to the host tools
if building for i.MX8X.
This allows to use the thud-next branch also with oe master.
Currently no changes are needed.
Provide the MACHINE_NAME variable which can be e.g. used as part of the
image name.
Add information required to build a Toradex Easy Installer image.
Only support the main SKU Colibri iMX8 QuadXPlus 2GB Wi-Fi / BT IT
for now since we do not know yet if the other SKU's need a special
device tree or other adjustments.
Only support the main SKU Apalis iMX8 QuadMax 4GB Wi-Fi / BT IT
Our downstream U-Boot provides a u-boot-nand.imx target prepending the
binary with a 1k block for easier flashing while the mainline U-Boot
does not.
Mimic the behaviour in a do_compile_append.
Use for all Toradex machines exept apalis-imx8 a mainline based U-Boot.
(For the i.MX8QM mainline is not yet able to boot the kernel)
Update the components which NXP forked or provides to the version
used in the 4.14.78_1.0.0_ga BSP.
Variables are not used only in the NXP BSP.
Also the _mx8 overrides are unneeded.
SERIAL_CONSOLE has been deprecated for a while now (see [1]) and is
replaced by SERIAL_CONSOLES.
[1]: https://www.yoctoproject.org/docs/2.7/ref-manual/ref-manual.html#migration-2.6-serial-console-deprecated
With the change to wic the used oe variable names changed.
We decided we won't do a BSP 3.0 for Vybrid.
For new designs we recommend ULL now.
With the move to use '+=' in the assignment the parsing order of the
files matters, as assignments with '=' will delete all previously
parsed '+=' assignments.
Change all assignments to '+='.
According to the Yocto manual v.2.6.1
(https://www.yoctoproject.org/docs/2.6.1/mega-manual/mega-manual.html#var-IMAGE_FSTYPES):
Due to the way the OpenEmbedded build system processes this variable, you
cannot update its contents by using _append or _prepend. You must use the +=
operator to add one or more options to the IMAGE_FSTYPES variable.
Signed-off-by: Gerard Salvatella <gerard.salvatella@toradex.com>
This re-enables building the Toradex Easy Installer image type.
SERIAL_CONSOLE has been deprecated for a while now.
While at it, move from ?= to a = assignment. Since imx-base.inc already
definces SERIAL_CONSOLES using ?= makes no sense.
The kernel class now sets RDEPENDS_${KERNEL_PACKAGE_NAME}-base so this include
needs to do the same, otherwise bitbake emits a warning and the kernel isn't
removed.
Actually make use of them various upgrades.
Add support for new SKU 0045 WiFi non-IT variant.
Device trees for the carrier board Aster are now available, deploy
them.
This is required since meta-freescale commit a4158e3425a7
("gstreamer1.0: Set DEFAULT_PREFERENCE as -1 to imx version") et. al.
and is analogous to meta-freescale-distro commit 29e7a3d322c7
("fsl-base.inc: Set PREFERRED_VERSION for Gstreamer to use i.MX Version"
Colibri iMX6ULL and Colibri iMX7 were added as according to the i.MX
Reference Manual L4.1.15_2.1.0-ga they at least could profit from the
Pixel Pipeline (PxP) DMA-ENGINE driver.
