2017-01-09 | packagegroup-fsl-gpu-libs: added to only deploy the libraries | Max Krummenacher | |
This provides an alternative to packagegroup-fsl-tools-gpu which installs examples and tools which pull in also the libraries but blows up image size. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com> | |||
2016-09-29 | meta-fsl-demos layer bbappends | Max Krummenacher | |
Move the appends on recipe's which are not in an essential required layer into a target layer specific directory and add them only if said layer is active in build/conf/bblayers.conf. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com> |
