path: root/recipes-bsp/alsa-state
2018-03-29alsa-state: add asound.state for Colibri iMX7 1GB (eMMC) modulesStefan Agner
Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2016-06-30alsa-state: add asound.state for Colibri iMX7 modulesStefan Agner
Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2015-08-07alsa-state: choose extended record volumeStefan Agner
The WM9715L AC97 codec supports two volume modes for audio capturing: basic (AC97 conform) and extended. The extended range allows smaller gain steps and a large range, hence use this mode by default.
2015-02-02alsa-state: update Vybrid default ALSA stateStefan Agner
Update default ALSA state for WM9712 AC97 codec support on 3.18 kernel.
2014-10-06colibri-imx6: add machine specific config filesMax Krummenacher
2014-08-04bbappends: remove the deprecated PRINC variableMax Krummenacher
2014-04-01asound.state: apalis-imx6 set volume to maximumMax Krummenacher
2014-04-01alsa-state: add file for iMX6Max Krummenacher
2013-11-21Machine: use the changed machinename colibri-vfMax Krummenacher
2013-10-10colibri-vf50: add the machine, kernel and u-bootMax Krummenacher
- also add the relevant configuration files
2013-01-29alsa: add Apalis-T30 initial asound.stateMax Krummenacher
2012-12-31update u-boot and kernel git versionsMax Krummenacher
remove testfile
2012-08-15L4T R15, oe-core Image V2.0Beta1Max Krummenacher
