2019-12-13 | alsa-state: add alsa config for verdin-imx8mm | Max Krummenacher | |
This gives the codec reasonable mixer defaults. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> | |||
2019-06-05 | alsa-state: increase volume for apalis-imx8 | Max Krummenacher | |
2019-05-09 | alsa-state: follow card rename in the apalis-imx8 kernel | Max Krummenacher | |
2019-04-30 | alsa-state: add alsa config for apalis-imx8 | Max Krummenacher | |
This sets the analog audio out as the default alsa card and gives that codec reasonable mixer defaults. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> | |||
2019-04-23 | colibri-vf: drop machine | Max Krummenacher | |
We decided we won't do a BSP 3.0 for Vybrid. For new designs we recommend ULL now. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> | |||
2018-03-29 | alsa-state: add asound.state for Colibri iMX7 1GB (eMMC) modules | Stefan Agner | |
Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> | |||
2016-06-30 | alsa-state: add asound.state for Colibri iMX7 modules | Stefan Agner | |
Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com> | |||
2015-08-07 | alsa-state: choose extended record volume | Stefan Agner | |
The WM9715L AC97 codec supports two volume modes for audio capturing: basic (AC97 conform) and extended. The extended range allows smaller gain steps and a large range, hence use this mode by default. | |||
2015-02-02 | alsa-state: update Vybrid default ALSA state | Stefan Agner | |
Update default ALSA state for WM9712 AC97 codec support on 3.18 kernel. | |||
2014-10-06 | colibri-imx6: add machine specific config files | Max Krummenacher | |
2014-08-04 | bbappends: remove the deprecated PRINC variable | Max Krummenacher | |
2014-04-01 | asound.state: apalis-imx6 set volume to maximum | Max Krummenacher | |
2014-04-01 | alsa-state: add file for iMX6 | Max Krummenacher | |
2013-11-21 | Machine: use the changed machinename colibri-vf | Max Krummenacher | |
2013-10-10 | colibri-vf50: add the machine, kernel and u-boot | Max Krummenacher | |
- also add the relevant configuration files | |||
2013-01-29 | alsa: add Apalis-T30 initial asound.state | Max Krummenacher | |
2012-12-31 | update u-boot and kernel git versions | Max Krummenacher | |
remove testfile | |||
2012-08-15 | L4T R15, oe-core Image V2.0Beta1 | Max Krummenacher | |
