I.e. reset the whole SoC rather than just the AP partition.
Related-to: ELB-2702
This fixes a following compiling error on verdin-imx8mm machine:
+| plat/imx/common/imx8m/imx_rdc.c: In function 'imx_rdc_set_masters':
+| plat/imx/common/imx8m/imx_rdc.c:146:9: error: 'ret' may be used uninitialized in this function [-Werror=maybe-uninitialized]
Signed-off-by: Ming Liu <ming.liu@toradex.com>
Related-to: ELB-2351
This is needed to build imx-atf version 1.5.
This helps that the user of the file (imx-boot) need not be aware of the
atf version.
The 2018.03 U-Boot of the 4.14.78 1.0.0 BSP failes booting. By reverting to ATF 1.5
it boots again.
This reverts commit 39ea358020e2f555c1fd36a1f9e193466c9d96f7.
This copes with the version upgrade in meta-freescale master to imx-atf 2.0
which is meant for BSP 4.14.98_2.0.0_ga.
