Update to a 2019.07 based U-Boot.
Use the openembedded master recipes for u-boot_2019.07 as a base.
This makes the u-boot recipe in recipes-bsp/u-boot-mainline/ obsolete,
delete it.
Add patches currently on the ML targeting Toradex boards and fetch
latest and greatest of master branch.
Otherwise U-Boot freezes before outputting anything.
Our downstream U-Boot provides a u-boot-nand.imx target prepending the
binary with a 1k block for easier flashing while the mainline U-Boot
does not.
Mimic the behaviour in a do_compile_append.
Remove two patches which make the apalis-imx6, colibri-imx6 SPL build fail.
They are not needed for a working U-Boot.
