path: root/recipes-bsp/u-boot/files/mx6/fw_env.config
2016-08-17u-boot-fw-utils: use negative offset for environmentStefan Agner
Rely on newly implemented configuration functionality to locate the environment at the end of the boot partition. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2015-10-30apalis/colibri_imx6/t30: u-boot-fw-utils: update fw_printenv/setenvMarcel Ziswiler
Introduce/update postinst code to dynamically adjust fw_env.config and fw_unlock_mmc.sh shell profile extension script to cope with our new unified eMMC layout: boot area partition 1 aka primary eMMC boot sector: with U-Boot boot loader and the U-Boot environment before the configblock at the end of that boot area partition
2014-08-04colibri-t20: add configuration to u-boot-fw-utilsMax Krummenacher
u-boot-fw-utils allows for U-Boot environmenmt access from Linux. Add the needed configuration file for colibri_t20 with a postinst script which choses the right NAND flash sector sizes from /proc/mtd While at it, fix some whitespace issues.
2014-08-04u-boot-fw-utils: add config für colibri-vf and apalis-imx6Max Krummenacher
