path: root/recipes-bsp/u-boot/u-boot-toradex-fsl-fw-utils_git.bb
2017-04-10u-boot: use the new version variables for localversionColibri-iMX7_LXDE-Image_2.7b2-20170410Colibri-iMX6_LXDE-Image_2.7b2-20170410Colibri-VF_LXDE-Image_2.7b2-20170410Apalis-iMX6_LXDE-Image_2.7b2-20170410Max Krummenacher
This results in a U-Boot banner: U-Boot 2016.11-2.7.2+g3e67ed8 (Apr 05 2017 - 16:16:38 +0200) While at it extract the versioning into its own bbappend so that we can upstream the base recipe to meta-freescale-3rdparty Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-04-10u-boot: update to latestMax Krummenacher
2017-04-07u-boot: use the new version variablesMax Krummenacher
2017-04-07meta-toradex-nxp: cleanup whitespace useMax Krummenacher
While at it remove double assignement to 'S'. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-04-07u-boot-toradex-fsl-fw-utils: inherit pkgconfigMax Krummenacher
2017-04-07u-boot: update to latest -nextMax Krummenacher
2017-01-12u-boot: update to latestColibri_iMX7_LinuxImageV2.7Beta1_20170112Colibri_iMX6_LinuxImageV2.7Beta1_20170112Colibri_VF_LinuxImageV2.7Beta1_20170112Apalis_iMX6_LinuxImageV2.7Beta1_20170112Max Krummenacher
2017-01-10u-boot-fsl-fw-utils: add u-boot-fw-utils to RPROVIDESMirza Krak
Otherwise packages that have a run-time dependency on u-boot-fw-utils will not build u-boot-toradex-fsl-fw-utils and instead use the "default" one. This was observed when layer is used together with poky. Signed-off-by: Mirza Krak <mirza.krak@gmail.com> Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com>
2017-01-10u-boot: update to latest nextMax Krummenacher
2017-01-09u-boot/kernel: update version string to 2.7Max Krummenacher
2017-01-09u-boot: upgrade to 2016.11 based versionMax Krummenacher
0001-fw_env.c-include-stdint.h-unconditionally.patch has been fixed upstream. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com>
2017-01-09u-boot: update to latest nextMax Krummenacher
2017-01-09u-boot: fix compileMax Krummenacher
fix errors due to missing uint* types. Move to u-boot git. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com>
2016-09-29u-boot: use latestMax Krummenacher
2016-08-17u-boot-fw-utils: use negative offset for environmentStefan Agner
Rely on newly implemented configuration functionality to locate the environment at the end of the boot partition. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-06-30u-boot, u-boot-fw-utils: update to latestStefan Agner
The upgrade is required to match to the latest update scripts which deploy the kernel and device tree into static UBI volumes. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-03-31u-boot: update to latest from 2015.04-toradex-nextMarcel Ziswiler
2016-03-30u-boot fsl utils: update to latest -next and add mx7Max Krummenacher
2015-12-15Update all U-Boot versions to latestMax Krummenacher
2015-11-03Update Linux kernel and U-Boot to latest.Marcel Ziswiler
2015-10-30apalis/colibri_imx6/t30: u-boot-fw-utils: update fw_printenv/setenvMarcel Ziswiler
Introduce/update postinst code to dynamically adjust fw_env.config and fw_unlock_mmc.sh shell profile extension script to cope with our new unified eMMC layout: boot area partition 1 aka primary eMMC boot sector: with U-Boot boot loader and the U-Boot environment before the configblock at the end of that boot area partition
2015-08-13colibri-vf: update u-boot fw-utils to latestMax Krummenacher
2015-05-18Apalis/Colibri: update U-Boot to latestMax Krummenacher
And use 2015.04-toradex branch
2015-05-18Apalis/Colibri: update U-Boot to latest in -nextMax Krummenacher
2015-05-12update to latest u-bootMax Krummenacher
2015-05-12update U-Boot and Colibri VFxx Linux to latest git revisionStefan Agner
2015-05-12update to latest u-bootMarcel Ziswiler
2015-05-12u-boot: use latest from gitMax Krummenacher
While at it remove warning about stripped fw_printenv binary when building u-boot-toradex-fsl-fw-utils.
2015-05-12Apalis/Colibri iMX6: kernel/U-Boot update to latest in -nextMax Krummenacher
Also deploy an additional device tree supporting a Colibri iMX6 with Analog Camera Module.
2015-05-12u-boot-toradex-fsl-fw-utils: fix compileMax Krummenacher
cross strip tool not found without this patch.
2015-05-12recipes: replace short DESCRIPTION with SUMMARYMax Krummenacher
The SUMMARY variable gives a short description of the package (<72 chars). A missing DESCRIPTION is automatically set to the content of SUMMARY.
2015-05-12u-boot-fw-utils: fix compiler optionsMax Krummenacher
With dizzy we got compiler errors when compiling with the new 4.9 gcc.
2015-02-03colibri-vf: update Linux kernel and U-Boot git hashesStefan Agner
Also update default defconfig for colibri-vf.
2014-12-19u-boot/u-boot-fw-utils: update all to latestMax Krummenacher
2014-10-30u-boot: iMX6/VF update to latest from gitMax Krummenacher
2014-10-20colibri-vf: u-boot: switch to 2014.10Stefan Agner
Use rebased U-Boot release 2014.10. The README has a new md5sum and U-Boots new build system has default configurations ending with defconfig too.
2014-08-04u-boot: update to latest git versionMax Krummenacher
2014-08-04u-boot-toradex: update to latest git versionMax Krummenacher
2014-08-04u-boot-fw-utils: add config für colibri-vf and apalis-imx6Max Krummenacher
2014-04-05u-boot-fw-utils: provide matching recipesMax Krummenacher
With the change to our own u-boot recipes the bbappend to the common u-boot-fw-utils recipe is no longer a sane solution. While at it cleanup COMPATIBLE_MACHINE style.
