While at it remove double assignement to 'S'.
Otherwise packages that have a run-time dependency on u-boot-fw-utils
will not build u-boot-toradex-fsl-fw-utils and instead use the
"default" one.
This was observed when layer is used together with poky.
Signed-off-by: Mirza Krak <mirza.krak@gmail.com>
0001-fw_env.c-include-stdint.h-unconditionally.patch has been fixed upstream.
fix errors due to missing uint* types.
Move to u-boot git.
Rely on newly implemented configuration functionality to locate the
environment at the end of the boot partition.
The upgrade is required to match to the latest update scripts which
deploy the kernel and device tree into static UBI volumes.
Introduce/update postinst code to dynamically adjust fw_env.config and
fw_unlock_mmc.sh shell profile extension script to cope with our new
unified eMMC layout:
boot area partition 1 aka primary eMMC boot sector:
with U-Boot boot loader and the U-Boot environment before the
configblock at the end of that boot area partition
And use 2015.04-toradex branch
While at it remove warning about stripped fw_printenv binary
when building u-boot-toradex-fsl-fw-utils.
Also deploy an additional device tree supporting a Colibri iMX6 with
Analog Camera Module.
cross strip tool not found without this patch.
The SUMMARY variable gives a short description of the package (<72 chars).
A missing DESCRIPTION is automatically set to the content of SUMMARY.
With dizzy we got compiler errors when compiling with the new 4.9 gcc.
Also update default defconfig for colibri-vf.
Use rebased U-Boot release 2014.10. The README has a new md5sum
and U-Boots new build system has default configurations ending
with defconfig too.
With the change to our own u-boot recipes the bbappend to
the common u-boot-fw-utils recipe is no longer a sane solution.
While at it cleanup COMPATIBLE_MACHINE style.
