2015-05-18 | Apalis/Colibri: update U-Boot to latest in -next | Max Krummenacher | |
2015-05-18 | Apalis iMX6 IT: u-boot: use the IT defconfig for IT | Max Krummenacher | |
2015-05-12 | update to latest u-boot | Max Krummenacher | |
2015-05-12 | update U-Boot and Colibri VFxx Linux to latest git revision | Stefan Agner | |
2015-05-12 | update to latest u-boot | Marcel Ziswiler | |
2015-05-12 | u-boot: use latest from git | Max Krummenacher | |
While at it remove warning about stripped fw_printenv binary when building u-boot-toradex-fsl-fw-utils. | |||
2015-05-12 | Apalis/Colibri iMX6: kernel/U-Boot update to latest in -next | Max Krummenacher | |
Also deploy an additional device tree supporting a Colibri iMX6 with Analog Camera Module. | |||
2015-05-12 | colibri_vf: update to U-Boot 2015.04/Linux 4.0 | Stefan Agner | |
2015-02-03 | colibri-vf: update Linux kernel and U-Boot git hashes | Stefan Agner | |
Also update default defconfig for colibri-vf. | |||
2015-01-09 | u-boot: build additional binary for Apalis iMX6Q 2GB IT | Max Krummenacher | |
The IT variant needs different RAM timings | |||
2014-12-19 | u-boot/u-boot-fw-utils: update all to latest | Max Krummenacher | |
2014-12-19 | colibri_vf: update U-Boot and Linux kernel git hashes | Stefan Agner | |
Two last minute fixes: Default Product/Vendor ID for USB peripheral in U-Boot and fix for the USB peripheral RNDIS freeze. | |||
2014-12-18 | Update all to latest and greatest U-Boot and Linux kernel. | Marcel Ziswiler | |
2014-12-16 | colibri-vf: switch to mainline kernel based on 3.18 | Stefan Agner | |
Switch default kernel recipe to linux-toradex-vf which will build a kernel based on the toradex 3.18-next branch. | |||
2014-12-11 | colibri-vf: update U-Boot | Max Krummenacher | |
2014-12-11 | apalis/colibri-imx6: U-Boot and Kernel for V1.0/V1.1 | Max Krummenacher | |
Update to a U-Boot and Kernel which can be used for Apalis iMX6 HW version V1.0 and V1.1. Also deploy additional device tree for Apalis iMX6 V1.0 modules | |||
2014-10-30 | u-boot: iMX6/VF update to latest from git | Max Krummenacher | |
2014-10-20 | colibri-vf: u-boot: switch to 2014.10 | Stefan Agner | |
Use rebased U-Boot release 2014.10. The README has a new md5sum and U-Boots new build system has default configurations ending with defconfig too. | |||
2014-10-06 | colibri-imx6: refactor recipes for new module | Max Krummenacher | |
2014-08-04 | u-boot: update to latest git version | Max Krummenacher | |
2014-08-04 | u-boot-toradex: update to latest git version | Max Krummenacher | |
2014-05-24 | colibri-vf: use latest u-boot and burnflash | Marcel Ziswiler | |
Use the latest U-Boot and burnflash. | |||
2014-05-07 | u-boot: make use of shared U-Boot branch | Stefan Agner | |
2014-04-30 | colibri-vf: switch to U-Boot 2014.04 and latest git | Stefan Agner | |
This commit switches Colibri VF machine to use the 2014.04 git branch. The change to latest U-Boot brings proper NAND hardware ECC support, which is also enabled in latest Linux kernel. Beside that, burnflash is updated to correctly work with the new U-Boot version and the altered Config Block location. | |||
2014-04-03 | u-boot: apalis-imx6 update to latest git version | Max Krummenacher | |
2014-04-02 | u-boot: apalis-imx6 update to latest git version | Max Krummenacher | |
2014-04-01 | u-boot: add Apalis iMX6 and Colibri VF recipe | Max Krummenacher | |
