Re-add U-Boot Toradex 2016.11 as Tezi (and TorizonCore) may still depend on it.
Update to a 2019.07 based U-Boot.
Use the openembedded master recipes for u-boot_2019.07 as a base.
This makes the u-boot recipe in recipes-bsp/u-boot-mainline/ obsolete,
delete it.
(cherry picked from commit a5f5d85e52717e136e692478fb5d822c1ce70046)
recipes-bsp/u-boot/u-boot-toradex-fsl-fw-utils_git.bb
(moved to meta-freescale-3party, githash now in bbappend)
Variables from tdx_version.conf are now provided by the distro.
Add defaults in case someone doesn't use our distro.
Acked-by: Philippe Schenker <philippe.schenker@toradex.com>
Include u-boot-toradex-env.inc will generate a uEnv.txt text
file containing the default environment of the U-Boot binary.
We move to use SPL/u-boot.img also in the recovery case.
Drop building the u-boot-recover.imx and no longer rename the
u-boot-spl.img file to the misleading name u-boot-spl.imx.
We changed the version variables in
meta-toradex-bsp-common/conf/tdx_version.conf
Set Toradex and git hash versions in the same way as what
is upstreamed to meta-freescale-3rdparty.
With UBOOT_CONFIG one can build several U-Boot configs, however
the current code does fail if these build mixed spl and non spl
based U-Boots.
This works around the issue by generating a fake SPL file and
delete it after its presence is no longer needed.
This can be used e.g. for a CI setup to do nightly builds of latest and
greatest.
To use HEAD of xxx-next instead of the pinned version one would add
in local.conf:
MACHINEOVERRIDES =. "use-head-next:"
Building the recipe with Poky leads to two errors:
| error: line 4: invalid tag value("^[A-Za-z0-9+._]+$") Release: Release: 2.7.3-gitr1c83a29
| error: Package has no %description: u-boot-toradex-2016.11.colibri_imx6
Use the + sign to separate the git revision and provide a recipe
description.
This results in a U-Boot banner:
U-Boot 2016.11-2.7.2+g3e67ed8 (Apr 05 2017 - 16:16:38 +0200)
While at it extract the versioning into its own bbappend so that we
can upstream the base recipe to meta-freescale-3rdparty
