Bump SRCREV hashes as used in build of Tue 12 Mar 2024 03:00:01 PM UTC
Matrix Build: image-tezi-dunfell-5.x.y-nightly-matrix 527
Matrix Build Status: SUCCESS
Triggered by: https://jenkins.int.toradex.com/job/image-tezi-dunfell-5.x.y-nightly-matrix/527
Signed-off-by: ci.toradex <cicd@toradex.com>
This fixes a following do_patch warning:
| WARNING: u-boot-toradex-1_2020.07+gitAUTOINC+4baed78646-r0 do_patch: Fuzz detected:
| Applying patch 0001-colibri_imx7-boot-linux-kernel-in-non-secure-mode.patch
| patching file include/configs/colibri_imx7.h
| Hunk #1 succeeded at 161 with fuzz 2 (offset 21 lines).
Signed-off-by: Thomas Keller <thomas.keller@toradex.com>
Bump SRCREV hashes as used in build of Thu 01 Feb 2024 08:01:01 AM UTC
Matrix Build: image-tezi-dunfell-5.x.y-nightly-matrix 517
Triggered by: https://jenkins.int.toradex.com/job/image-tezi-dunfell-5.x.y-nightly-matrix/517
Bump SRCREV hashes as used in build of Sat 18 Nov 2023 07:26:11 AM UTC
Matrix Build: image-torizoncore-dunfell-5.x.y-nightly-matrix 764
Triggered by: https://jenkins.int.toradex.com/job/image-torizoncore-dunfell-5.x.y-nightly-matrix/764
Bump SRCREV hashes as used in build of Sat 17 Jun 2023 07:24:33 AM UTC
Matrix Build: image-torizoncore-dunfell-5.x.y-nightly-matrix 741
Triggered by: https://jenkins.int.toradex.com/job/image-torizoncore-dunfell-5.x.y-nightly-matrix/741
Bump SRCREV hashes as used in build of Sat Feb 18 08:03:52 UTC 2023
Matrix Build: image-torizoncore-dunfell-5.x.y-nightly-matrix 723
Triggered by: https://jenkins.int.toradex.com/job/image-torizoncore-dunfell-5.x.y-nightly-matrix/723
Bump SRCREV hashes as used in build of Wed Jul 13 19:00:53 UTC 2022
Matrix Build: image-tezi-dunfell-5.x.y-nightly-matrix 409
Triggered by: https://jenkins.int.toradex.com/job/image-tezi-dunfell-5.x.y-nightly-matrix/409
imx-scfw was put back one commit (8dda739), as we don't want to pull in the
latest change in there.
Bump SRCREV hashes as used in build of Thu Jun 30 12:38:39 UTC 2022
Matrix Build: image-tdxref-dunfell-5.x.y-nightly-matrix 708
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-nightly-matrix/708
The u-boot-with-spl.imx binary (if available), will be copied in the
DEPLOYDIR for MACHINE colibri-imx6 and apalis-imx6.
This binary is needed to implement bootloader software update
where having only one binary instead of SPL + u-boot.bin
simplifies things especially in the cloud platform side.
Signed-off-by: Stefano Viola <stefano.viola@toradex.com>
Bump SRCREV hashes as used in build of Wed May 25 22:07:55 UTC 2022
Matrix Build: image-tdxref-dunfell-5.x.y-nightly-matrix 672
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-nightly-matrix/672
Bump SRCREV hashes as used in build of Fri Apr 29 19:08:19 UTC 2022
Matrix Build: image-tezi-dunfell-5.x.y-nightly-matrix 339
Triggered by: https://jenkins.int.toradex.com/job/image-tezi-dunfell-5.x.y-nightly-matrix/339
Bump SRCREV hashes as used in build of Fri Feb 25 20:26:12 UTC 2022
Matrix Build: image-tezi-dunfell-5.x.y-nightly-matrix 285
Triggered by: https://jenkins.int.toradex.com/job/image-tezi-dunfell-5.x.y-nightly-matrix/285
Bump SRCREV hashes as used in build of Fri Jan 28 19:12:26 UTC 2022
Matrix Build: image-tezi-dunfell-5.x.y-nightly-matrix 258
Triggered by: https://jenkins.int.toradex.com/job/image-tezi-dunfell-5.x.y-nightly-matrix/258
Bump SRCREV hashes as used in build of Mon Jan 3 18:45:18 UTC 2022
Matrix Build: image-tezi-dunfell-5.x.y-nightly-matrix 230
Triggered by: https://jenkins.int.toradex.com/job/image-tezi-dunfell-5.x.y-nightly-matrix/230
Bump SRCREV hashes as used in build of Wed Dec 1 02:33:29 UTC 2021
Matrix Build: image-torizoncore-dunfell-5.x.y-nightly-matrix 473
Triggered by: https://jenkins.int.toradex.com/job/image-torizoncore-dunfell-5.x.y-nightly-matrix/473
Bump SRCREV hashes as used in build of Wed Oct 27 16:24:15 UTC 2021
Matrix Build: image-tdxref-dunfell-5.x.y-nightly-matrix 464
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-nightly-matrix/464
Bump SRCREV hashes as used in build of Thu Sep 30 08:44:58 UTC 2021
Matrix Build: image-tdxref-dunfell-5.x.y-nightly-matrix 435
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-nightly-matrix/435
Bump SRCREV hashes as used in build of Mon Aug 30 13:56:07 UTC 2021
Matrix Build: image-tdxref-dunfell-5.x.y-nightly-matrix 407
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-nightly-matrix/407
Bump SRCREV hashes as used in build of Wed Aug 4 04:59:24 UTC 2021
Matrix Build: image-tdxref-dunfell-5.x.y-nightly-matrix 381
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-nightly-matrix/381
This allows building OE master for Colibri VF50/VF61 again.
Bump SRCREV hashes as used in build of Tue Jun 29 02:05:00 UTC 2021
Matrix Build: image-tdxref-dunfell-5.x.y-nightly-matrix 346
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-nightly-matrix/346
Matrix Build: image-tdxref-dunfell-5.x.y-nightly-matrix 319
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-nightly-matrix/319
Additionally use latest for u-boot-toradex.git branch toradex_2020.07
A following error was observed:
| Can't write signature for 'signature@1' signature node in 'conf@imx6ull-colibri-wifi-eval-v3.dtb' conf node: <unknown error>
| uboot-mkimage Can't add hashes to FIT blob: -1
This is caused by a wrong return value being used in uboot source.
The return value '-ENOSPC' of fit_set_timestamp function does not match
the caller fit_image_write_sig's expection which is '-FDT_ERR_NOSPACE'.
Fix it by not calling fit_set_timestamp, but call fdt_setprop instead.
Related-to: TOR-1704
Signed-off-by: Ming Liu <ming.liu@toradex.com>
Merge of the NXP BSP 5.4.70-2.3.2
Related-to: ELB-3957
Matrix Build: image-tdxref-dunfell-5.x.y-nightly-matrix 269
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-nightly-matrix/269
Bump SRCREV hashes as used in build of Sun Feb 28 21:30:15 UTC 2021
Matrix Build: image-tdxref-dunfell-5.x.y-nightly-matrix 232
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-nightly-matrix/232
Bump SRCREV hashes as used in build of Tue Feb 2 09:26:34 UTC 2021
Matrix Build: image-torizoncore-dunfell-5.x.y-nightly-matrix 205
Triggered by: https://jenkins.int.toradex.com/job/image-torizoncore-dunfell-5.x.y-nightly-matrix/205
Related-to: ELB-3325
This reverts commit 1811f925aa4bf28c706fbab529cc20661bcf307a.
With the uprev of the downstream kernel the default device tree name
is now the same for mainline and downstream and the needed changes
are done in U-Boot. The patch is thus no longer needed.
Bump SRCREV hashes as used in build of Tue Dec 29 21:45:13 UTC 2020
Matrix Build: image-tdxref-dunfell-5.x.y-nightly-matrix 175
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-nightly-matrix/175
Bump SRCREV hashes as used in build of Mon Dec 28 14:48:13 UTC 2020
Matrix Build: image-tdxref-dunfell-5.x.y-nightly-matrix 172
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-nightly-matrix/172
Unify the file used for the modules which use eMMC to store the
U-Boot environmant.
Change to use the stable symlink to the emmc boot area to specify
the location of the U-Boot environment.
Related-to: ELB-3293
Bump SRCREV hashes as used in build of Fri Nov 20 11:48:52 UTC 2020
Matrix Build: image-tdxref-dunfell-5.x.y-nightly-matrix 134
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-nightly-matrix/134
| WARNING: u-boot-toradex do_patch: Fuzz detected:
| Applying 0001-colibri_imx7-boot-linux-kernel-in-non-secure-mode.patch
| Hunk #1 succeeded at 140 with fuzz 2 (offset -9 lines).
Related-to: TOR-1518
Bump SRCREV hashes as used in build of Mon Nov 2 02:36:22 UTC 2020
Matrix Build: image-tdxref-dunfell-5.x.y-nightly-matrix 116
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-nightly-matrix/116
Matrix Build: image-tdxref-dunfell-5.x.y-nightly-matrix 115
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-nightly-matrix/115
meta-freescale does that now in imx-boot resulting in the following bitbake
error:
| ERROR: imx-boot-1.0-r0 do_deploy_setscene: The recipe imx-boot is trying to install files into a shared area when those files already exist. Those files and their manifest location are:
| /build/krm/oe-core_master/build/deploy/images/verdin-imx8mm/imx-boot-tools/mkimage_uboot
| (matched in manifest-verdin_imx8mm-u-boot-toradex.deploy)
Related-to: ELB-3081
Matrix Build: image-tdxref-dunfell-5.x.y-nightly-matrix 84
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-nightly-matrix/84
While NXP i.MX 7 downstream requires the Linux kernel to boot in secure
mode mainline/upstream requires non-secure mode instead, as it properly
uses PSCI to control further cores.
Bump SRCREV hashes as used in build of Tue Sep 29 12:07:44 UTC 2020
Matrix Build: image-tdxref-dunfell-5.x.y-nightly-matrix 81
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-nightly-matrix/81
When using UBOOT_CONFIG, U-Boot is built in a subdirectory named
after the defconfig name (e.g. ${B}/colibri_imx7_defconfig).
So let's make it possible to override the directory where the padding
is done for NAND devices.
Related-to: TOR-1332
Signed-off-by: Sergio Prado <sergio.prado@toradex.com>
Related-to: ELB-2758
The changes include:
- Drop PREFERRED_PROVIDER_u-boot-fw-utils from machine conf.
- Drop u-boot-toradex-fw-utils recipes.
- Drop fw_unlock_mmc.sh, that's not needed for libubootenv.
- Drop u-boot.inc, use default u-boot.inc from OE layer.
- Add fw_env.config to uboot recipe.
- Set UBOOT_INITIAL_ENV to u-boot-initial-env, which is being referred
in libubootenv.
Related-to: ELB-2552
(cherry picked from commit cc99b62c767130adc2e005470a243853a1476f24)
(cherry picked from commit bd2a8c344695e2ffc489e6084991201edf304403)
