The workaround for U-Boot being compiled with and without SPL
assumes a certain directory structure. For machines only building
one U-Boot, the workaround may introduce and error.
Fix this.
This allows for machine variants, additonally it adds colibri-imx6ull
This results in a U-Boot banner:
U-Boot 2016.11-2.7.2+g3e67ed8 (Apr 05 2017 - 16:16:38 +0200)
While at it extract the versioning into its own bbappend so that we
can upstream the base recipe to meta-freescale-3rdparty
While at it remove double assignement to 'S'.
With the new U-Boot MTD partitioning schema mtd3 is used for the
environment.
Without this the default fw_env.config gets deployed.
Otherwise packages that have a run-time dependency on u-boot-fw-utils
will not build u-boot-toradex-fsl-fw-utils and instead use the
"default" one.
This was observed when layer is used together with poky.
Signed-off-by: Mirza Krak <mirza.krak@gmail.com>
0001-fw_env.c-include-stdint.h-unconditionally.patch has been fixed upstream.
fix errors due to missing uint* types.
Move to u-boot git.
Do not use the function keyword, then the script works fine with
with Busybox' shell implementation.
While we use only one erase block for the U-Boot environment, we
reserve four in case there are bad blocks in the environment area.
Specify the number of blocks so that the Linux utilities are able
to read/write the environment even if the first block of the
environment is bad.
Rely on newly implemented configuration functionality to locate the
environment at the end of the boot partition.
The upgrade is required to match to the latest update scripts which
deploy the kernel and device tree into static UBI volumes.
This allows building U-Boot supporting Toradex Colibri iMX7 modules.
Based on upstream Freescale/NXP 3.14.52_1.1.0_ga release which is based on 2015.04.
machine/u-boot/kernel files have been added to meta-fsl-arm-extra.
Use them from there now.
Change the name form u-boot-it.imx to u-boot.imx-it.
This prepares for the upcomming move of the i.MX 6 based modules BSP
Introduce/update postinst code to dynamically adjust fw_env.config and
fw_unlock_mmc.sh shell profile extension script to cope with our new
unified eMMC layout:
boot area partition 1 aka primary eMMC boot sector:
with U-Boot boot loader and the U-Boot environment before the
configblock at the end of that boot area partition
Follow the rename imx6q-apalis-eval_v1_0.dtb to imx6q-apalis_v1_0-eval.dtb
in the kernel.
The v1_0 denotes the Apalis module version, not the evaluation board version.
The mmc unlock function causes troubles when using Poky reference
distribution since Poky uses the busybox shell:
/etc/rc5.d/S09xserver-nodm: /etc/profile.d/fw_unlock_mmc.sh: line 2: syntax error: unexpected "("
This avoids X getting at all.
This patch does not solve the underlying problem, but works around it
by moving the script to the u-boot-toradex-fw-utils recipe, which is
not installed by the Poky images by default.
And use 2015.04-toradex branch
While at it remove warning about stripped fw_printenv binary
when building u-boot-toradex-fsl-fw-utils.
Also deploy an additional device tree supporting a Colibri iMX6 with
Analog Camera Module.
