2014-03-26 | mqxboot/libmcc: fixed dependencies to kernel module | Stefan Agner | |
We need to have the kernel modules header at build time, so mark it as not only a runtime dependency. | |||
2014-03-18 | u-boot Txx: update to latest | Max Krummenacher | |
2014-03-17 | kernel/u-boot: update to latest git revision | Stefan Agner | |
2014-03-17 | vybrid: backport Cortex-M utilites from meta-fsl | Stefan Agner | |
- Add utility mqxboot to load firmware into IRAM and reset M4 - Add kernel module mcc needed by libmcc - Add multi-core communication library libmcc for message queue based communication with Cortex-M core | |||
2014-02-10 | kernel/u-boot: update to latest git | Stefan Agner | |
2013-11-21 | u-boot: colibri-vf: use the unified u-boot 50/61 | Max Krummenacher | |
2013-11-21 | Machine: use the changed machinename colibri-vf | Max Krummenacher | |
2013-10-23 | u-boot: update to latest git version | Max Krummenacher | |
2013-10-10 | colibri-vf50: add the machine, kernel and u-boot | Max Krummenacher | |
- also add the relevant configuration files | |||
2013-10-10 | u-boot-fw-utils: add bbappend to use the same u-boot sources | Max Krummenacher | |
2013-10-07 | u-boot: clean up recipe | Max Krummenacher | |
2013-09-22 | u-boot: don't build the examples | Max Krummenacher | |
- they do fail because they don't heed the private libgcc | |||
2013-08-23 | u-boot: update to latest git version | Max Krummenacher | |
2013-06-26 | u-boot: update to latest git revision | Max Krummenacher | |
2013-03-04 | remove unused files | Max Krummenacher | |
2013-01-29 | u-boot: add Apalis-T30 | Max Krummenacher | |
- add Apalis-T30 - remove u-boot machine definition, this is also defined in the machine conf. | |||
2013-01-29 | alsa: add Apalis-T30 initial asound.state | Max Krummenacher | |
2013-01-22 | u-boot: update to latest on git.toradex.com | Max Krummenacher | |
2012-12-31 | update u-boot and kernel git versions | Max Krummenacher | |
remove testfile | |||
2012-12-18 | u-boot: remove all modification, they are moved to u-boot git | Max Krummenacher | |
2012-10-18 | u-boot: update to 16a9368a88a28252ea1daedc1df03ccc49ea5b22 | Max Krummenacher | |
2012-10-18 | removed *~ backup files from git repo | Max Krummenacher | |
2012-10-18 | u-boot: update to a1ab5236759b1cd6fae427517d44d7be90b02c07 | Max Krummenacher | |
2012-08-23 | Use kernel and u-boot from git.toradex.com | Max Krummenacher | |
Move changes done to other repos into .bbappends in meta-toradex | |||
2012-08-15 | L4T R15, oe-core Image V2.0Beta1 | Max Krummenacher | |
2012-07-21 | pull u-boot unified for vibrante and l4t and the corresponding l4t kernel | Max Krummenacher | |
2012-06-12 | - mklibs is no longer downloadable in the 0.1.33 version, upgrade to next ↵ | Max Krummenacher | |
version | |||
2012-06-03 | u-boot base from meta instead of a copy from meta-ti | Max Krummenacher | |
fix u-boot to no longer fail at runtime, (write beyond array) | |||
2012-06-03 | Initial commit | Max Krummenacher | |
