Delete binary firmware that is no longer used.
This adds a SCFW that was created with:
./create_and_deploy.sh
scfw_export_mx8qx_b0/platform/main/build_info.h:
SCFW_BRANCH imx_4.14.98_2.0.5_ga
SCFW_BUILD 3353UL
SCFW_COMMIT 0x494c97f3UL
SCFW_DATE "Aug 15 2019"
SCFW_DATE2 Aug_15_2019
SCFW_TIME "18:06:25"
Our SCFW git hash: a5af9ce
The python dependency has been handled properly in OE by the following
commit 3b0b1630:
[ u-boot: Fix pylibfdt generation ]
Drop the redundant python dependency here, they would slow down u-boot
build.
Signed-off-by: Ming Liu <ming.liu@toradex.com>
Branch name: imx_4.14.98_2.0.0_ga
Build version: 3332
Commit ID: 0x0cb6f758b
Build date: May 20 2019
Build time: 10:58:51
Our SCFW git hash:
74b74e5
Colibri iMX8X now has its environment also stored in the eMMC boot area.
Deploy the same configuration as for the Apalis iMX8 also for the Colibri iMX8X.
The kernel for Apalis iMX6 now uses mmc2 as the instance for the eMMC.
Follow that.
Build version: 3332
Our SCFW git hash:
f74abf46
This is needed to build imx-atf version 1.5.
This one is required for fastboot recovery integration.
This fixes RAM issue as see on Apalis iMX8QP and updates to latest RPA
with all fixes and e.g. proper CBT enablement.
Build version: 3332
Our SCFW git hash:
e8090f2
Re-add U-Boot Toradex 2016.11 as Tezi (and TorizonCore) may still depend on it.
This allows to use u-boot-fw-utils in image recipes.
Update to a 2019.07 based U-Boot.
Use the openembedded master recipes for u-boot_2019.07 as a base.
This makes the u-boot recipe in recipes-bsp/u-boot-mainline/ obsolete,
delete it.
SCFW implementing proof of concept 1 GB resp. 2 GB vs. 2 GB resp. 4 GB
DDR SKU handling based on fuses indicating SoC being i.MX 8QP resp. 8DX
vs. 8QM resp. 8QXP.
Build version: 3332
Our SCFW git hash:
71682f29
Note: this also requires a later U-Boot supporting SKU memory sizing.
This helps that the user of the file (imx-boot) need not be aware of the
atf version.
The 2018.03 U-Boot of the 4.14.78 1.0.0 BSP failes booting. By reverting to ATF 1.5
it boots again.
This reverts commit 39ea358020e2f555c1fd36a1f9e193466c9d96f7.
Update to version based on NXP SCFW 1.2.2.
Build version: 3332
Our SCFW git hash:
56ee0444
Upstream dropped support for i.MX8QM A0 silicon with the update to the
4.14.98 2.0.0 BSP.
Add patches currently on the ML targeting Toradex boards and fetch
latest and greatest of master branch.
This prevents fetcher errors if a machines does not provide its
specific file.
The Apalis iMX8 QM V1.0A require a specific DCD. Inject that DCD file
and change the Makefile to actually use it.
(The DCD for B0 silicon integrated in the SCFW and irrelevant here)
The Apalis iMX8 QM V1.0A are not fused but strapped to boot from SD card.
Revert the environment change which makes them boot from eMMC.
This copes with the version upgrade in meta-freescale master to imx-atf 2.0
which is meant for BSP 4.14.98_2.0.0_ga.
Copied and adapted from:
openembedded-core/meta/recipes-bsp/u-boot/u-boot-fw-utils_2018.07.bb
Otherwise U-Boot freezes before outputting anything.
Our downstream U-Boot provides a u-boot-nand.imx target prepending the
binary with a 1k block for easier flashing while the mainline U-Boot
does not.
Mimic the behaviour in a do_compile_append.
Remove two patches which make the apalis-imx6, colibri-imx6 SPL build fail.
They are not needed for a working U-Boot.
Changes:
Update to version based on NXP SCFW 1.1.2.
Branch name: imx_4.14.78_1.0.0_ga
Build version: 3014
Commit ID: 0x0f0226b37
Build date: Mar 27 2019
Build time: 14:47:32
Our SCFW git hash:
8f160f9
This sets the analog audio out as the default alsa card and gives
that codec reasonable mixer defaults.
Only A0 silicon has and needs a DCD file, B0 silicon and likely later
revisions have the DCD information as part of the SCFW file.
