This is a copy from meta-freescale of the 7.8 recipes updated to
firmware-imx-8.0.
(cherry picked from commit a5f5d85e52717e136e692478fb5d822c1ce70046)
recipes-bsp/u-boot/u-boot-toradex-fsl-fw-utils_git.bb
(moved to meta-freescale-3party, githash now in bbappend)
Variables from tdx_version.conf are now provided by the distro.
Add defaults in case someone doesn't use our distro.
The recipe got moved to meta-freescale-3rdparty.
Rework additional settings into a bbappend.
This reverts commit 9644f8c076d677d6c74674e889eb1dc66d36f827.
This now lives in meta-freescale.
This reverts commit de504a1923f09ea25e0beb1ccc375e113e207067.
Acked-by: Philippe Schenker <philippe.schenker@toradex.com>
Pulled from c9bb48f2887667c59b8353e7ab5e44e41324375a on
meta-freescale/master.
Pulled from 1594c64aa5d51a0c97835f6548215fb0b48e0a34 on
Include u-boot-toradex-env.inc will generate a uEnv.txt text
file containing the default environment of the U-Boot binary.
We move to use SPL/u-boot.img also in the recovery case.
Drop building the u-boot-recover.imx and no longer rename the
u-boot-spl.img file to the misleading name u-boot-spl.imx.
Colibri iMX6ULL uses raw NAND, hence fw_unlock_mmc.sh is not
required. Make sure fw_unlock_mmc.sh only gets deployed for
modules using eMMC flash.
We changed the version variables in
meta-toradex-bsp-common/conf/tdx_version.conf
Unify the way the fw-utils are cross compiled.
While at it format the file identically.
Set Toradex and git hash versions in the same way as what
is upstreamed to meta-freescale-3rdparty.
With UBOOT_CONFIG one can build several U-Boot configs, however
the current code does fail if these build mixed spl and non spl
based U-Boots.
This works around the issue by generating a fake SPL file and
delete it after its presence is no longer needed.
Upstream U-Boot 2016.11 for all NXP based modules to meta-freescale-3rdparty.
Remove the files for the older 2015.04 based U-Boot.
Signed-off-by: Drew Moseley <drew.moseley@northern.tech>
This can be used e.g. for a CI setup to do nightly builds of latest and
greatest.
To use HEAD of xxx-next instead of the pinned version one would add
in local.conf:
MACHINEOVERRIDES =. "use-head-next:"
RPM packaging does not allow a dash '-' in the revision name.
Building the recipe with Poky leads to two errors:
| error: line 4: invalid tag value("^[A-Za-z0-9+._]+$") Release: Release: 2.7.3-gitr1c83a29
| error: Package has no %description: u-boot-toradex-2016.11.colibri_imx6
Use the + sign to separate the git revision and provide a recipe
description.
Add fw_env.config and make sure unlock eMMC gets installed.
The workaround for U-Boot being compiled with and without SPL
assumes a certain directory structure. For machines only building
one U-Boot, the workaround may introduce and error.
Fix this.
This allows for machine variants, additonally it adds colibri-imx6ull
This results in a U-Boot banner:
U-Boot 2016.11-2.7.2+g3e67ed8 (Apr 05 2017 - 16:16:38 +0200)
While at it extract the versioning into its own bbappend so that we
can upstream the base recipe to meta-freescale-3rdparty
While at it remove double assignement to 'S'.
With the new U-Boot MTD partitioning schema mtd3 is used for the
environment.
Without this the default fw_env.config gets deployed.
Otherwise packages that have a run-time dependency on u-boot-fw-utils
will not build u-boot-toradex-fsl-fw-utils and instead use the
"default" one.
This was observed when layer is used together with poky.
Signed-off-by: Mirza Krak <mirza.krak@gmail.com>
0001-fw_env.c-include-stdint.h-unconditionally.patch has been fixed upstream.
