This allows building OE master for Colibri VF50/VF61 again.
(cherry picked from commit 6c8aa68911936a004a4febf369ec31e254b89c1c)
(cherry picked from commits 4a58243 0a39b69 336a66d)
This reverts commit 6afef1e44279d41bb8fdda11dfecbf8cdd213f8d.
The fix is now applied in openembedded core.
Commit 8628a276a0 ('u-boot-tools: fix a mkimage signature issue')
Matrix Build: image-tdxref-dunfell-5.x.y-nightly-matrix 319
Matrix Build Status: SUCCESS
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-nightly-matrix/319
Signed-off-by: ci.toradex <cicd@toradex.com>
Additionally use latest for u-boot-toradex.git branch toradex_2020.07
(cherry picked from commit ce70bcafb720725ef78fb3f47c2da153372099fa)
A following error was observed:
| Can't write signature for 'signature@1' signature node in 'conf@imx6ull-colibri-wifi-eval-v3.dtb' conf node: <unknown error>
| uboot-mkimage Can't add hashes to FIT blob: -1
This is caused by a wrong return value being used in uboot source.
The return value '-ENOSPC' of fit_set_timestamp function does not match
the caller fit_image_write_sig's expection which is '-FDT_ERR_NOSPACE'.
Fix it by not calling fit_set_timestamp, but call fdt_setprop instead.
Related-to: TOR-1704
Signed-off-by: Ming Liu <ming.liu@toradex.com>
(cherry picked from commit 7cba654ca343f52b3b8258cc2073d1287fa96c16)
Merge of the NXP BSP 5.4.70-2.3.2
Related-to: ELB-3957
(cherry picked from commit c84522a358749514844a175c8b88fb3885c9e4ec)
(cherry picked from commit 63b9da9241ad1b1b2c71dc933ec6c2ee0550cc61)
Matrix Build: image-tdxref-dunfell-5.x.y-nightly-matrix 269
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-nightly-matrix/269
(cherry picked from commit a9ae3ea1f4ad181edbe940a99943a8256a811326)
Bump SRCREV hashes as used in build of Sun Feb 28 21:30:15 UTC 2021
Matrix Build: image-tdxref-dunfell-5.x.y-nightly-matrix 232
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-nightly-matrix/232
(cherry picked from commit 01d520a809ad84b8c41ec655e95a413a44c83b9e)
Bump SRCREV hashes as used in build of Tue Feb 2 09:26:34 UTC 2021
Matrix Build: image-torizoncore-dunfell-5.x.y-nightly-matrix 205
Triggered by: https://jenkins.int.toradex.com/job/image-torizoncore-dunfell-5.x.y-nightly-matrix/205
(cherry picked from commit 599cd72b82723ac096bb5c9bea2d82bdc6b38185)
bitbake fails if the mkimage_uboot symlink in the work directory
already exists. Delete it before recrating it.
| ERROR: imx-boot-1.0-r0 do_compile: Execution of '..temp/run.do_compile.43961' failed with exit code 1:
| cp: '...recipe-sysroot-native//usr/bin/mkimage' and '...git/iMX8M/mkimage_uboot' are the same file
(cherry picked from commit 5eed1ed77e0dd047034ef12fb7d5ad90f746629b)
This fixes a following do_patch warning:
| WARNING: u-boot-toradex do_patch: Fuzz detected:
| Applying 0001-colibri_imx7-boot-linux-kernel-in-non-secure-mode.patch
| patching file include/configs/colibri_imx7.h
| Hunk #1 succeeded at 140 with fuzz 2 (offset -9 lines).
Related-to: TOR-1518
(cherry picked from commit f5f752d9d7b8a684b1afaccb41eb6a6f6c8c2c08)
This is now in meta-freescale in a newer version.
U-Boot dosn't show the version on Apalis iMX8/iMX8X and Colibri iMX8X.
Provide BUILD_STRING for all builds, not just for _mx8mm, _mx8mp.
Completes a39fd31 ("imx-atf: provide proper BUILD_STRING value")
Related-to: ELB-3188
(cherry picked from commit 7562948e27c359b256f1bb7c26d3e1c368acad8d)
meta-freescale introduced the use-imx-security-controller-firmware.bbclass
to set the seco file name. Use that class.
Also follow the changed compatible machine setting.
Related-to: ELB-3324
(cherry picked from commit 5d0036f130ff8eba00ed2001860badd9e97b9084)
(cherry picked from commit 433fef501f58153a51da6be2c5959c5545912f3b)
(cherry picked from commit 833009c7677562e456baca16f620216e56134cec)
(cherry picked from commit 31830e24f7a5e2e1d4f44c1cdf2705494f1e3243)
Related-to: ELB-3325
(cherry picked from commit 28964fd4bbc3d141cc88d90ff56b9aa80c361916)
This reverts commit 1811f925aa4bf28c706fbab529cc20661bcf307a.
With the uprev of the downstream kernel the default device tree name
is now the same for mainline and downstream and the needed changes
are done in U-Boot. The patch is thus no longer needed.
(cherry picked from commit cf6263859fa0b39276fa0f535c2333027db19db7)
Bump SRCREV hashes as used in build of Tue Dec 29 21:45:13 UTC 2020
Matrix Build: image-tdxref-dunfell-5.x.y-nightly-matrix 175
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-nightly-matrix/175
(cherry picked from commit 1cd4cc7dc068e86c4ee3cbee76c34cd64156f295)
Bump SRCREV hashes as used in build of Mon Dec 28 14:48:13 UTC 2020
Matrix Build: image-tdxref-dunfell-5.x.y-nightly-matrix 172
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-nightly-matrix/172
(cherry picked from commit 71d211918ec18b0e6538accc691b1d25f572d53e)
The following build errors was observed on ubuntu 16.04:
| ./mkimage_uboot -E -p 0x3000 -f u-boot.its u-boot.itb
| ./mkimage_uboot: error while loading shared libraries: libssl.so.1.1: cannot open shared object file: No such file or directory
or:
| ./mkimage_uboot: /usr/lib/x86_64-linux-gnu/libcrypto.so.1.1: version `OPENSSL_1_1_1' not found (required by ./mkimage_uboot)
the issue is caused by OE builds native tools with a relative runpath:
$ aarch64-tdx-linux-objdump -p iMX8M/mkimage_uboot | egrep 'RPATH|RUNPATH'
RUNPATH $ORIGIN/../lib:$ORIGIN/../../lib
when mkimage_uboot is copied from ${STAGING_BINDIR_NATIVE} to ${S}, the
'$ORIGIN/../lib:$ORIGIN/../../lib' directories dont exist and ld hence
fall back to load libssl.so.1.1/libcrypto.so.1.1 from host system.
It could be fixed by creating a symbolic link in source to
${STAGING_BINDIR_NATIVE}/mkimage instead of copying it.
Related-to: ELB-3394
(cherry picked from commit be8f831ce0728062bacc686f2ab9178e8c53031f)
(cherry picked from commit c01ca63e3e6939121cc0202b91ad20651f65a22e)
(cherry picked from commit cabae110d1b5dd2c4898475decdb1b9c3fcd62a1)
Unify the file used for the modules which use eMMC to store the
U-Boot environmant.
Change to use the stable symlink to the emmc boot area to specify
the location of the U-Boot environment.
Related-to: ELB-3293
(cherry picked from commit bddf19691f67257c30d14cc1d17300316a5fbb0c)
Bump SRCREV hashes as used in build of Fri Nov 20 11:48:52 UTC 2020
Matrix Build: image-tdxref-dunfell-5.x.y-nightly-matrix 134
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-nightly-matrix/134
(cherry picked from commit f2afc2bc33bee8e44560d7e79de7e4f908d742d0)
Copy and adapt the Verdin iMX8MM definition and bump the hash.
Related-to: ELB-3208
(cherry picked from commit 97c2aae46672fda3494e2ce263b7137dd3f6ab92)
Bump SRCREV hashes as used in build of Mon Nov 2 02:36:22 UTC 2020
Matrix Build: image-tdxref-dunfell-5.x.y-nightly-matrix 116
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-nightly-matrix/116
(cherry picked from commit fa41855fb9a79718aa16b8e76b0255a40e8d16f3)
Matrix Build: image-tdxref-dunfell-5.x.y-nightly-matrix 115
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-nightly-matrix/115
(cherry picked from commit d06fe6247f3dae6743cf7e2b1d9606b96aeb15a8)
ATF commit hash is calculated during build time invoking in Makefile
git describe, which doesn't work properly in OE sandbox env.
Provide explicitly the build info string as a build option for make.
Related-by: ELB-3188
Signed-off-by: Igor Opaniuk <igor.opaniuk@toradex.com>
(cherry picked from commit a39fd312c9c688336c09fd84818a7f7fe131209a)
meta-freescale is updated to this version.
Related-to: ELB-3081
(cherry picked from commit bc5999636a3cbc4150deb8d6995b6ac21b7f72dc)
meta-freescale does that now in imx-boot resulting in the following bitbake
error:
| ERROR: imx-boot-1.0-r0 do_deploy_setscene: The recipe imx-boot is trying to install files into a shared area when those files already exist. Those files and their manifest location are:
| /build/krm/oe-core_master/build/deploy/images/verdin-imx8mm/imx-boot-tools/mkimage_uboot
| (matched in manifest-verdin_imx8mm-u-boot-toradex.deploy)
(cherry picked from commit fca85306b40067ed7007d546cf25805e8c78e0c4)
Exact same version and do_compile task have been added in
meta-freescale layer, let's drop our bbappend recipe.
(cherry picked from commit d11072fbfc7ea243ff68acdb27abe6b4d8000361)
The firmware-imx has been upgraded to 8.8 in meta-freescale, we need to
adapt to that change by dropping some variables that already in
meta-freescale.
(cherry picked from commit 0c22d7c6911fbf1f8159fcc4fbf2d7074b0b7812)
0001-Allow-BUILD_STRING-to-be-set-in-.revision-file.patch was dropped in
meta-freescale, drop it from SRC_URI.
(cherry picked from commit 686fdecbdfec417717fc7056172d1676a7b55eda)
Using ${nonarch_base_libdir} instead of ${PREFIX}/lib or
${base_libdir}, this ensures it would not mess up multilib builds.
Related-to: TOR-1415
(cherry picked from commit 2c9c04fb2e7d5c7db6fe88a978189c40841a7c28)
Matrix Build: image-tdxref-dunfell-5.x.y-nightly-matrix 84
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-nightly-matrix/84
(cherry picked from commit f339ccb51bf47a07d31d79fc984101547da048f7)
While NXP i.MX 7 downstream requires the Linux kernel to boot in secure
mode mainline/upstream requires non-secure mode instead, as it properly
uses PSCI to control further cores.
(cherry picked from commit 65ad0c9327000b100eaf51958023f8dac7642753)
Bump SRCREV hashes as used in build of Tue Sep 29 12:07:44 UTC 2020
Matrix Build: image-tdxref-dunfell-5.x.y-nightly-matrix 81
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-nightly-matrix/81
(cherry picked from commit 18f08d5336e188f8f7ba5212bb3f63c4751a51fb)
When using usrmerge, the install path should be prefixed by /usr.
Signed-off-by: Sergio Prado <sergio.prado@toradex.com>
(cherry picked from commit 36228213a2f9b03e8259aa03c196a600364d8130)
In order to make git hash bumping work with the imx-sc-firmware we need
to have our own recipe in our layer. This also has the advantage that
the recipe name reflects the actual package version (PV) again. Use
imx-sc-firmware-toradex to make sure we do not interfere with the NXP
provided variant.
Make sure our machines pick imx-sc-firmware-toradex by setting
PREFERRED_PROVIDER accordingly.
Related-to: AUT-355
This allows building with gcc 10.
The update has arrived in meta-freescale dunfell.
Related-to: ELB-2758
This allows to drop the patches applied on our internal fork.
When using UBOOT_CONFIG, U-Boot is built in a subdirectory named
after the defconfig name (e.g. ${B}/colibri_imx7_defconfig).
So let's make it possible to override the directory where the padding
is done for NAND devices.
Related-to: TOR-1332
From NXP BSP 5.4.24-2.1.0.
