2016-03-30 | psplash-angstrom_git.bbappend: removed, *.bb no longer exists | Max Krummenacher | |
2015-08-07 | Revert "systemd: restore userspace firmware loading support" | Max Krummenacher | |
This reverts commit bd2d32bf3a8460c87849e75ad01e11450d8cda10. Remove the backport, is part of fido. | |||
2015-05-18 | Revert "systemd-machine-id-commit: add standalone recipe" | Max Krummenacher | |
Angstom Dizzy now uses systemd V218 so there is no need to build a component seperately anymore. This reverts commit 16b8b392ad048566729f30d7c3887d1bfdf21bd4. | |||
2015-05-18 | systemd: restore userspace firmware loading support | Jonathan Liu | |
This changes the minimum required Linux version from 3.7 back to 3.0. [YOCTO #7409] Signed-off-by: Jonathan Liu <net147@gmail.com> Signed-off-by: Richard Purdie <richard.purdie@linuxfoundation.org> backported from openembedded-core, commit 31163abc7bedd477c1aad10e6d1f47dbee194513 | |||
2015-05-18 | Revert "systemd: fix DHCP on link state change" | Max Krummenacher | |
This reverts commit 3cf2edb10f5e8ac60db7ca2e71d1e754a177d08c. Conflicts: recipes-core/systemd/systemd_%.bbappend | |||
2015-05-12 | systemd: fix DHCP on link state change | Stefan Agner | |
When the link goes down, the DHCP service has been disabled, while there is no corresponding functionality which enables the service when the link goes up again. This fix is taken from systemd 217. | |||
2015-03-05 | journald: remove journald.conf patch | Max Krummenacher | |
meta-angstrom now overrides the effect of the patch and provides the journald.conffile in full. To override a setting either create the file with your settings in meta-toradex/recipes-core/systemd/systemd/journald.conf or edit meta-angstrom/recipes-core/systemd/systemd/journald.conf. | |||
2014-12-18 | systemd-machine-id-commit: add standalone recipe | Max Krummenacher | |
2014-10-30 | timestamp-service: remove in favor of meta-angstrom patch | Max Krummenacher | |
2014-08-04 | timestamp-service: change to new timestamp format | Max Krummenacher | |
Patch pending in meta-angstrom | |||
2014-08-04 | util-linux: fstrim: remove now integrated backport | Max Krummenacher | |
2014-08-04 | Use generic bbappend files | Max Krummenacher | |
This uses the % wildcard for recipe matching. remove the deprecated PRINC variable while at it. | |||
2014-04-01 | util-linux bbappend: update to match bb version | Max Krummenacher | |
2014-04-01 | journald patch: update to systemd 206 | Max Krummenacher | |
2014-04-01 | systemd bbappend: update to match bb version | Max Krummenacher | |
2014-02-04 | util-linux: add fstrim | Max Krummenacher | |
Add the fstrim utility to Colibri T30 image. The utility allows to send trim commands to the underlaying flash translation layer, which allows too free not used flash sectors and those improve wear- leveling | |||
2013-09-22 | systemd: systemd bbappend update to version 199 | Max Krummenacher | |
2013-09-22 | systemd: follow update of recipe with bbappend | Max Krummenacher | |
2013-06-26 | systemd: fix patch path so the default -p 1 applies | Max Krummenacher | |
2013-06-07 | systemd-journald: limit journal size | Max Krummenacher | |
2012-08-24 | ${BPN} errors to psplash-angstrom instead of psplash, fetch fails. | Max Krummenacher | |
