path: root/recipes-devtools/imx-loader
2016-03-14imx-loader: update to later versionMax Krummenacher
Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2015-05-12recipes: replace short DESCRIPTION with SUMMARYMax Krummenacher
The SUMMARY variable gives a short description of the package (<72 chars). A missing DESCRIPTION is automatically set to the content of SUMMARY.
2014-11-13cbootimage/imx-loader/mtd-utils/tegrarcm: fix 32-bit build of our bsp/devtoolsMarcel Ziswiler
2014-08-04imx-loader: use latest from gitMax Krummenacher
2014-04-01imx-loader: update to latest from gitMax Krummenacher
2014-03-31imx-loader: update to latest from gitMax Krummenacher
2014-03-31imx-loader: fix warnings during buildMax Krummenacher
- install into local dir first and then do the sysroots deployment
2014-03-26imx-loader: add UART/USB loader for i.MX/Vybrid SoCsStefan Agner
imx-loader allows to load data directly into memory through the Serial Download Protocol (SDP). This package contains two binaries, the imx_usb and the imx_uart utility for the two supported hardware links. Configuration are available from the /etc/imx-loader.d/ directory.
