path: root/recipes-fsl/packagegroups
2017-01-09packagegroup-fsl-gpu-libs: added to only deploy the librariesMax Krummenacher
This provides an alternative to packagegroup-fsl-tools-gpu which installs examples and tools which pull in also the libraries but blows up image size. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com>
2016-09-29meta-fsl-demos layer bbappendsMax Krummenacher
Move the appends on recipe's which are not in an essential required layer into a target layer specific directory and add them only if said layer is active in build/conf/bblayers.conf. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com>
2015-08-07gpu-viv-bin: package has been renamed and splitMax Krummenacher
gpu-viv-bin-mx6q -> imx-gpu-viv with a bunch of subpackages.
