path: root/recipes-kernel/linux/linux-toradex-3.14.52/apalis-imx6/defconfig
2017-12-22linux-toradex: upstream kernel 4.1 for apalis-/colibri-imx6, colibri-imx7Max Krummenacher
Upstream the kernel for a fslc-imx 4.1-2.0.x based kernel for Apalis/Colibri iMX6 and Colibri iMX7 to meta-freescale-3rdparty. Remove the files for linux-toradex_3.14.52 and linux-toradex_4.1.15 kernels. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-10-03linux-toradex: add squashfs configuration in all mx6 defconfigsMax Krummenacher
snapd requires squashfs kernel module but this has not been added to all defconfigs. Follow commit f0d525d36e915076416a443eb15a69efdcac1e73 or the images which add the snapd packagegroup will not build Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com>
2016-11-21linux-toradex: configure IPv6 SIT driver as moduleApalis_TK1_LinuxImageV2.6.1Beta2_20161122Stefan Agner
SIT tunnels (IPv6 over IPv4) are not often used hence configure the driver as a module. This also gets rid of the extra network interface sit0 by default. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-06-30linux-toradex: update to latest -nextMax Krummenacher
2016-03-30linux-toradex_3.14.52: update to latest on -next and use also for mx6Max Krummenacher
Update defconfigs and drop picking the defconfig from the kernel sources. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
