path: root/recipes-kernel/linux/linux-toradex-4.14-2.3.x/colibri-imx6ull/defconfig
2020-04-15linux-toradex: synchronise defconfigsOleksandr Suvorov
Basically, as per the following commit from the toradex_4.14-2.3.x-imx branch on git://git.toradex.com/linux-toradex.git ab66d6c48c8e78e74ebbf41505db65b0830e6fd7 ARM: apalis/colibri-imx6/7/6ull: enable options for backports 8d6cc5a3e9a2cf349c4d42e13c4449f16512651e ARM: apalis/colibri-imx6/7/6ull: disable wireless drivers c666f52447fa426fdc414bb1c922d89969f25385 arm64: defconfig: enable options required for backports d55c4e1ff7f1a6b23908d45bfec48b2c717d13fe arm64: defconfig: disable wireless drivers Related-to: ELB-2687 Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
Basically, as per the following commit from the toradex_4.14-2.3.x-imx branch on git://git.toradex.com/linux-toradex.git 19a90652d70208c755d3339e21f6bfc8cae04b82: ARM: apalis/colibri: defconfig: remove backported drivers 76b17e9c0b6f0245dc76c59062257bea2d0d6a0f: arm64: apalis/colibri: defconfig: remove backported drivers Related-to: ELB-2388 Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
2020-04-03linux-toradex: synchronise defconfigsMarcel Ziswiler
Basically, as per the following two commits from the toradex_4.14-2.3.x-imx branch on git://git.toradex.com/linux-toradex.git b1df9c77a53e92dc6b993007e3d8bb1f3cc61bf6: colibri imx6ull: defconfig: enable building backports-5.4 ad4d419f1b24e1d986e2fe956c1f3ca7d1eab93f: apalis/colibri_imx6/-imx6ull/_imx7/-imx8/8x_defconfig: config refresh Related-to: ELB-2388 Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2020-03-12linux-toradex: update to 4.14-2.3.xMax Krummenacher
Related-to: ELB-2351 Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
