path: root/recipes-kernel/linux/linux-toradex-4.4
2017-10-03linux-toradex_4.4: Resync with kernel tree defconfigStefan Agner
Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-10-03linux-toradex: update defconfigsDominik Sliwa
Adjust defconfigs for use with backports Signed-off-by: Dominik Sliwa <dominik.sliwa@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com>
2016-11-21linux-toradex: configure IPv6 SIT driver as moduleApalis_TK1_LinuxImageV2.6.1Beta2_20161122Stefan Agner
SIT tunnels (IPv6 over IPv4) are not often used hence configure the driver as a module. This also gets rid of the extra network interface sit0 by default. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-09-29colibri_vf: Update defconfig to build rpmsg and remoteprocSanchayan Maity
Update defconfig to build rpmsg and remoteproc. Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-06-30colibri_vf: fix audio and add L2 switchStefan Agner
Resynchronize defconfig with the git tree version: The audio Codec Machine driver was missing hence the sound card got not detected by the SAI driver. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2016-06-30colibri_vf: update defconfig to enable IIO sysfs triggerSanchayan Maity
While we enable CONFIG_IIO_SYSFS_TRIGGER in kernel source defconfig this is not enabled in defconfig being used in OpenEmbedded. This results in sysfs triggers not being enabled by default in an image build with OpenEmbedded. This is already observed with our last release 2.6 Beta1 image. Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com> Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2016-03-14colibri-vf: add linux-toradex_4.4.bbMax Krummenacher
Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
