Basically, as per the following commit from the
toradex_vf_4.4-next branch on git://git.toradex.com/linux-toradex.git
25e7f6f94e42b16a6d5298122e1e4dee0e6bc5b6
colibri_vf_defconfig: add support of backports-5.4
Related-to: ELB-2724
Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
This adds CONFIG_USER_DEBUG to all defconfigs.
Adjust defconfigs for use with backports
SIT tunnels (IPv6 over IPv4) are not often used hence configure
the driver as a module. This also gets rid of the extra network
interface sit0 by default.
Update defconfig to build rpmsg and remoteproc.
Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com>
Resynchronize defconfig with the git tree version:
The audio Codec Machine driver was missing hence the sound card
got not detected by the SAI driver.
While we enable CONFIG_IIO_SYSFS_TRIGGER in kernel source defconfig
this is not enabled in defconfig being used in OpenEmbedded. This
results in sysfs triggers not being enabled by default in an image
build with OpenEmbedded. This is already observed with our last
release 2.6 Beta1 image.
