While at it add a config for colibri-imx6ull, add the Atmel touch driver and
follow the move of the colibri-imx7 -> mx7 override in the non rt defconfig.
snapd requires squashfs kernel module but this has not been added
to all defconfigs.
Follow commit f0d525d36e915076416a443eb15a69efdcac1e73
or the images which add the snapd packagegroup will not build
To select the kernel use a preferred provider variable in your
configuration files (e.g. local.conf):
PREFERRED_PROVIDER_virtual/kernel = "linux-toradex-fsl-rt"
Signed-off-by: Brandon Shibley <brandon.shibley@toradex.com>
