path: root/recipes-kernel/linux
2017-07-01linux-toradex: 4.1-2.0.x: update to latestMarcel Ziswiler
Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Dominik Sliwa <dominik.sliwa@toradex.com>
2017-06-30linux-toradex: 4.1-2.0.x: snapd squashfs configurationMarcel Ziswiler
2017-06-30linux-toradex_4.4: update to latest for vybridMarcel Ziswiler
2017-06-09linux-toradex-rt: add preempt rt for vf50/vf61Stefan Agner
Add Linux kernel recipe which patches the Toradex Colibri VF50/VF61 kernel with the 4.4.60-rt73 PREEMPT RT patch set. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-06-09linux-toradex: disable otp driverStefan Agner
Disable the fusing/one-time-programmable driver by default. It allows to blow fuses which might make the module unusable with a simple sysfs write... Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-04-10linux-toradex_4.4: update to latestMax Krummenacher
Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-04-10linux-toradex_4.1-2.0.x: update to latestMax Krummenacher
2017-04-07linux: use the new version variablesMax Krummenacher
2017-04-07meta-toradex-nxp: cleanup whitespace useMax Krummenacher
While at it remove double assignement to 'S'. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-04-07linux-toradex_4.4: update to latest -nextMax Krummenacher
2017-04-07linux-toradex: 4.1-2.0.x: update to latest -nextMax Krummenacher
2017-04-07linux-toradex-rt: add a real-time kernel recipe for 4.1-2.0.xBrandon Shibley
To select the kernel use a preferred provider variable in your configuration files (e.g. local.conf): PREFERRED_PROVIDER_virtual/kernel = "linux-toradex-fsl-rt" Signed-off-by: Brandon Shibley <brandon.shibley@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-04-07linux-toradex: enable bluetooth in colibri imx7 defconfigStefan Agner
Configure Bluetooth to be built as kernel modules by default. This allows to make use of USB/SDIO based Bluetooth solutions easier. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-01-12linux-toradex_4.4: update to latestMax Krummenacher
2017-01-12linux-toradex_4.1-2.0.x: update to latestMax Krummenacher
2017-01-10linux-toradex_4.1-2.0.x: update to latest nextMax Krummenacher
Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com>
2017-01-10linux-toradex_4.4: update to latest nextMax Krummenacher
2017-01-09u-boot/kernel: demote version string to 2.6.1 for older recipesMax Krummenacher
2017-01-09u-boot/kernel: update version string to 2.7Max Krummenacher
2017-01-09kernel: add 4.1-2.0.x recipe and defconfigsMax Krummenacher
This kernels are based on the fslc community kernel which in turn are based on the NXP 4.1.15 released kernels. They can be used for Apalis iMX6, Colibri iMX6, and Colibri iMX7. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com>
2017-01-09linux-toradex_4.1.15: update to latest nextMax Krummenacher
2017-01-09linux-toradex_3.14.52: update to latest nextMax Krummenacher
2017-01-09linux-toradex_3.14.28.bbappend: drop, recipe removed from meta-fsl-arm-extraMax Krummenacher
Kernel upgraded to 3.14.52 kernel. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com>
2017-01-09linux-toradex_3.14.52: kernel updated in meta-fsl-arm-extraMax Krummenacher
2017-01-09linux-toradex_4.4: moved to meta-fsl-arm-extraMax Krummenacher
2017-01-09linux-toradex_4.1.15: moved to meta-fsl-arm-extraMax Krummenacher
2017-01-09linux vf: update to latest nextMax Krummenacher
2017-01-09linux imx7: update to latest nextMax Krummenacher
2017-01-09linux imx6: update to latest nextMax Krummenacher
2016-11-21linux-toradex: configure IPv6 SIT driver as moduleApalis_TK1_LinuxImageV2.6.1Beta2_20161122Stefan Agner
SIT tunnels (IPv6 over IPv4) are not often used hence configure the driver as a module. This also gets rid of the extra network interface sit0 by default. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-10-01colibri-vf: update kernel to latestColibri_iMX7_LinuxImageV2.6.1Beta1_20160929Colibri_iMX6_LinuxImageV2.6.1Beta1_20160929Colibri_VF_LinuxImageV2.6.1Beta1_20161001Apalis_iMX6_LinuxImageV2.6.1Beta1_20160929Marcel Ziswiler
Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com>
2016-09-30colibri-vf: update kernel to latestMarcel Ziswiler
2016-09-29linux-toradex: Auto-load rpmsg/remoteproc modules during bootSanchayan Maity
Auto-load rpmsg/remoteproc modules during boot. Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com> Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2016-09-29colibri_vf: Update defconfig to build rpmsg and remoteprocSanchayan Maity
Update defconfig to build rpmsg and remoteproc. Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-09-29linux vf: update to latestMax Krummenacher
2016-09-29colibri-imx7: synchronize defconfigStefan Agner
Synchronize defconfig with kernel git. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-09-29linux imx7: update to latestMax Krummenacher
2016-09-29linux imx6: update to latestMax Krummenacher
2016-06-30linux-toradex: update to latestMax Krummenacher
2016-06-30colibri_vf: fix audio and add L2 switchStefan Agner
Resynchronize defconfig with the git tree version: The audio Codec Machine driver was missing hence the sound card got not detected by the SAI driver. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2016-06-30linux-toradex: update to latest -nextMax Krummenacher
2016-06-30colibri-imx7: synchronize defconfigStefan Agner
Synchronize defconfig with kernel git. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2016-06-30colibri-imx7: add kernel 4.1.15 recipeMax Krummenacher
Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2016-06-30colibri_vf: update defconfig to enable IIO sysfs triggerSanchayan Maity
While we enable CONFIG_IIO_SYSFS_TRIGGER in kernel source defconfig this is not enabled in defconfig being used in OpenEmbedded. This results in sysfs triggers not being enabled by default in an image build with OpenEmbedded. This is already observed with our last release 2.6 Beta1 image. Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com> Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2016-04-11linux-toradex-fsl-rt: Added a real-time kernel recipe for 3.14.52Brandon Shibley
A new i.MX6/i.MX7 real-time 3.14.52 kernel recipe was added with a modified PREEMPT_RT patch to accomodate the backports applied to the Toradex kernel. To select the kernel use a preferred provider variable in your configuration files (e.g. local.conf): PREFERRED_PROVIDER_virtual/kernel = "linux-toradex-fsl-rt" Signed-off-by: Brandon Shibley <brandon.shibley@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-03-31linux-toradex_3.14.52: autoload USB gadget modulesMax Krummenacher
Use KERNEL_MODULE_AUTOLOAD to load USB gadget support. This is required for libusbg (gadget-import) to work. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-03-30linux-toradex_4.4: update to latest on -nextMax Krummenacher
2016-03-30linux-toradex_3.14.52: update to latest on -next and use also for mx6Max Krummenacher
Update defconfigs and drop picking the defconfig from the kernel sources. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-03-30linux-toradex-fsl-rt: Added a real-time kernel recipeBrandon Shibley
A new i.MX6 real-time kernel recipe was added with a modified PREEMPT_RT patch to accomodate the backports applied to the Toradex kernel. To select the kernel use a preferred provider variable in your configuration files (e.g. local.conf): PREFERRED_PROVIDER_virtual/kernel = "linux-toradex-fsl-rt" Signed-off-by: Brandon Shibley <brandon.shibley@toradex.com> Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2016-03-30linux-toradex_4.4: autoload USB gadget modulesStefan Agner
Use KERNEL_MODULE_AUTOLOAD to load USB gadget support. This is required for libusbg (gadget-import) to work. Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
