Update to L4.9.123-2.3.0_8mm_ga release.
Update to branch toradex_4.9-2.3.x-imx based on 4.9-2.3.x-imx branch of
linux-fslc currently re-based to 4.9.144.
Acked-by: Philippe Schenker <philippe.schenker@toradex.com>
Adjust defconfigs for use with backports
While at it use consistently the .xz compressed rt-patch file.
The device tree got changed to use the simple card driver, so enable it
in the defconfig.
While at it remove the IMX_SGTL5000 driver now replaced by the simple card driver.
While at it remove the unused ESAI driver.
While at it remove the unused CS42XX8_I2C codec driver.
The linux-toradex and linux-toradex-rt recipe adds a directory
with valid defconfigs to FILESEXTRAPATHS. Bitbake chooses the
first defconfig which it founds, which in that case is the one
from linux-toradex...
Include linux-toradex first, and then prepend the path from the
linux-toradex-rt recipe to make sure the defconfig for the -rt
kernel will be used.
However, in this scenario the PV variable can not be used since
linux-toradex_4.9-1.0.x.bb appends PV with image version and git
hash. Avoid using variables to avoid any ambiguity.
Add kernel recipe which applies the PREEMPT RT patchset. Patches
used in the 4.1 kernel are either obsolete or have been updated.
The patch "Work around CPU stalls in the imx-sdma driver" seems
not to be necessary. The kernel did not show the reported stack
trace after one night of cyclictest while audio running.
Include Toradex version specification to make sure that Toradex BSP
version appears in the Linux kernel version. Without the include the
Linux version only reports the git hash (4.9.67-+g1db9f06).
The Linux 4.4 kernel for Vybrid is considered stable at this point,
remove the 4.1 kernel recipe.
Disable regulator framework debug messages by default on all
SoCs including Colibri iMX7/iMX6ULL.
Adding LEDS_TRIGGERS.
This adds CONFIG_USER_DEBUG to all defconfigs.
Add recipe and defconfigs for the NXP Linux 4.9 GA 1.0.0 based kernel.
We changed the version variables in
meta-toradex-bsp-common/conf/tdx_version.conf
Set Toradex and git hash versions in the same way as what
is upstreamed to meta-freescale-3rdparty.
Upstream the kernel for a fslc-imx 4.1-2.0.x based kernel for Apalis/Colibri iMX6
and Colibri iMX7 to meta-freescale-3rdparty.
Remove the files for linux-toradex_3.14.52 and linux-toradex_4.1.15 kernels.
The 2.7.2 image version is now upstreamed to meta-freescale-3rdparty.
While at it add a config for colibri-imx6ull, add the Atmel touch driver and
follow the move of the colibri-imx7 -> mx7 override in the non rt defconfig.
This can be used e.g. for a CI setup to do nightly builds of latest and
greatest.
To use HEAD of xxx-next instead of the pinned version one would add
in local.conf:
MACHINEOVERRIDES =. "use-head-next:"
All kernel drivers to support eMMC are already present, hence this
uses the same defconfig as colibri-imx7 machine uses.
Thus use a soc override to provide the defconfig for both
colibri-imx7, colibri-imx7-emmc.
linux-toradex-4.1-2.0.x/defconfig is not building for machine
apalis-imx6, colibri-imx6, or colibri-imx7.
But the kernel does not (no longer`) build for this configuration.
| LD init/built-in.o
| drivers/built-in.o: In function `mxc_hdmi_disp_init':
| coresight-etm-cp14.c:(.text+0x4499c): undefined reference to `mxc_cea_mode'
Also include the patch from Julio Cruz which allows to use the external
vivante kernel module from meta-freescale.
snapd requires squashfs kernel module but this has not been added
to all defconfigs.
Follow commit f0d525d36e915076416a443eb15a69efdcac1e73
or the images which add the snapd packagegroup will not build
Add Linux kernel recipe which patches the Toradex Colibri VF50/VF61
kernel with the 4.4.60-rt73 PREEMPT RT patch set.
Disable the fusing/one-time-programmable driver by default. It
allows to blow fuses which might make the module unusable with
a simple sysfs write...
While at it remove double assignement to 'S'.
